May 16, 2025, 10:38:34 PM *
Author Topic: ratios  (Read 3923 times)
fe-ute56
« on: September 19, 2004, 07:20:47 AM »
hello i would like to know what ratio diff centre i have to use for fe ute .i am running 202 3 speed all syncro  and 13 inch wheels. plus what  color speedo drive to make speedo read true . thanks .all info appreciated.
« Reply #1 on: September 19, 2004, 11:37:44 AM »
to match your standard speedo,or to get better hi way cruise speed,as its a very loaded question you ask.gearbox in 3 and 4 speed holdens FX to WB are all 1 to 1 final drive
« Last Edit: September 19, 2004, 11:39:04 AM by nicko » Logged
« Reply #2 on: September 20, 2004, 09:47:46 AM »
I would think 3.36 would be good for you.  Start with yellow speedo gear and work from there.
fe-ute56
« Reply #3 on: September 21, 2004, 08:43:40 AM »
thank you both for your help.
what model holden were 3.36 diffs in ken
for example torana htgk etc please
thanks
« Reply #4 on: September 21, 2004, 09:33:18 PM »
EH (possibly EJ?) onwards, not sure when they stopped.  3.36 ratio diffs aren't hard to get.
earlyholdenfan
« Reply #5 on: September 22, 2004, 01:09:40 AM »
Similar Question here guys, what would I need for an EK running 186 and trimatic  to get reasonable highway and still good driveability around town(majority of time)??
Been told find a 3:55 and also told try 3:36 any help?Huh
and what colour drive yellow as well??
(sorry it is off topic a bit)
Matt
« Last Edit: September 22, 2004, 01:09:58 AM by earlyholdenfan » Logged
FCwagon
« Reply #6 on: September 22, 2004, 02:13:07 AM »
Hi Matt,
I have an FB with 186 - Trimatic and am running a 3.36 diff. Good off the line torque and not high revving on the freeway. I'm using a light blue (25T) gear because my speedo has been re-callibrated in the past and still  reads fast. With a standard speedo a yellow gear would be about right if you've got 65 series tyres.
cheers,
Leigh
Red & white is alright
oldgmh
« Reply #7 on: September 22, 2004, 06:39:36 AM »
I run a 202 trimatic in an EK with a 3.36 diff ( from HQ) and 13 inch wheels which gives good acceleration and cruising.
I am considering running 3.08 to give more relaxed highway cruising when keeping with the traffic at 110kph.
IMHO a 3.55 ratio is too short with 13 inch wheels.
« Last Edit: September 22, 2004, 06:42:00 AM by earlee » Logged
fe-ute56
« Reply #8 on: September 22, 2004, 07:18:54 AM »
thank you all .
i should be right frm here
« Reply #9 on: September 22, 2004, 07:56:48 AM »
the 2.78 and 3.08 are the only diffs suitable for a trimatic and 13 inch wheels the next step down is the 3.36 and sitting at 100kmh it revs at 3100rpm which is far too hi for hiway cruising this is why i have posted an ad in parts wanted on forum as my car just sucks the juice as soon as i go on the hiway.if you are going to tow a caravan or heavy trailer regulary the the 3.08 is best ratio for trimatic.
earlyholdenfan
« Reply #10 on: September 24, 2004, 07:58:47 AM »
Thanks guys, one of the reasons for the red conversion was to tow a van so looks like the 3.08 may be the go!
Cheers now off to the parts wanted section!
Matt
Page created in 0.044 seconds with 20 queries.
