July 26, 2025, 06:46:59 PM *
Author Topic: generator to alternator  (Read 5695 times)
chainsaw
« on: June 15, 2004, 04:50:46 AM »
I'd like to change the original generator to an altenator.  Can someone help?  What do I need to do/what size altenator/other advice???
« Reply #1 on: June 17, 2004, 07:58:55 AM »
Hi Chainsaw,
I've used a 65amp Bosch alternator with built in regulator with a modified red motor mounting bracket.
Hope this helps, Wink
Regards ACE Cool
« Last Edit: June 17, 2004, 07:59:44 AM by ACE » Logged
chainsaw
« Reply #2 on: June 18, 2004, 06:26:09 AM »
Thanks Ace Wink Can you please tell me; What was the Alternator off ? how much did you need to alter the bracket and what if any changes to the wireing? Are you happy with the change?  Huh Have had my FE for 7 years with little trouble but starting to need a little work now.  Kiss
« Reply #3 on: June 19, 2004, 12:39:48 AM »
Hi Chainsaw,
I've emailled you a pic of the modified alternator bracket with instructions on how to wire it up. Wink
Regards ACE Cool
Trevor_B
Melbourne VIC
« Reply #4 on: June 19, 2004, 01:12:24 AM »
ACE,
Any chance of posting the wiring instructions?
I've got a self regulating 55 amp unit that was removed during a respray. I've done some re-wiring as well and now not sure about the main power out wire ie the one that comes from the threaded terminal with nut. I assume this goes straight to the postitive termianl on the battery??
The other connection is a spade connection which I assume goes to the Gen indicator light in the instrumentation panel?
Thanks,
Trevor_B
« Reply #5 on: June 19, 2004, 01:21:01 AM »
Hi Trevor_B,
Your assumptions are correct Grin Grin Grin Grin Grin Grin Grin Grin
Regards ACE Cool
Trevor_B
Melbourne VIC
« Reply #6 on: June 19, 2004, 08:24:06 AM »
Thanks ACE,
good to be sure of the correct wiring - saves the embarrassment of sparks, smoke and a panicked rush for the fire extinguisher!
Trevor_B
mick wilson
« Reply #7 on: June 30, 2004, 11:13:49 PM »
ACE,
I am also wanting to convert to alternator, any chance you could send me picture of bracket + wiring + what Alternator did you use and what car was it from. My email address is micwil@bigpond.net.au
Many Thanks
Mick Wilson
(Just_Mick)
« Reply #8 on: July 01, 2004, 03:25:33 AM »
Hi Mick,
Email is on its way. Wink
Regards ACE Cool
mick wilson
« Reply #9 on: July 01, 2004, 05:03:56 AM »
Thanks ACE, you are a legend !!!
Rgds
Mick (Just_Mick)
RUBBLE
FC WAGONS ARE COOOOOOL
« Reply #10 on: July 01, 2004, 06:03:29 AM »
hey ace Wink
cani have a copy to Huh
cheers rubble
rubble69@mcmedia.com.au
« Reply #11 on: July 01, 2004, 09:27:31 PM »
There seems to be a lot of interest in this topic.  ACE, how about you send me the info and we can add it to our Tech Info section?
EJ_Dave
« Reply #12 on: July 02, 2004, 06:41:44 AM »
I put an HQ alternator in my EJ (14V 55amp) . It had an external regulator (also HQ I think) which bolted into the same position as the original and even used the original bolt holes. Hooked up to the original wiring too I think.  If the same regulator was used in the FE/FC this might work. Details are a bit sketchy as it was a while back.
David
Page created in 0.052 seconds with 20 queries.
