November 17, 2024, 06:09:49 AM *
Author Topic: steering wheel  (Read 7234 times)
Phantom
« on: May 26, 2004, 06:04:09 AM »
G'day all,
               Has anyone out there restored their steering wheel , i have a large cracks at the base of the arm , what is the best thing to fill it with bog? or is an epoxy resin the best thing to use, and where do i buy it from , etc
                                   Cheers Rusty
Bogans rule
Cat
« Reply #1 on: May 26, 2004, 10:48:23 AM »
Hey Rusty,
There was a post about 12 months ago about reconditioning a steering wheel.  Try a search for it, or ret might know where it's at.
Cat
Zoom zoom!
Phantom
« Reply #2 on: May 27, 2004, 03:21:44 AM »
Thanks CAT
Bogans rule
HARKO
« Reply #3 on: May 27, 2004, 09:02:47 AM »
Rusty ,I Redone my FBs steering wheel about two years back with bog and white 2k , The pretty large cracks have come back as a hairline fracture type crack but considering its done daily duty in the past two years and I hang off it for stability around corners with a face full of Maccas ,the flexing and bending had to do something.
And the 2k paint was sprayed on in the shed with no booth or lights and looks just as good now after all the grease and food and rubbing as it did when i sprayed it.. Would highly recommend doing it.
Phantom
« Reply #4 on: May 27, 2004, 09:11:23 AM »
Thank you Harko, that is what i will do , did you rub the whole wheel down with wet and dry also?
                         Cheers Rusty
Bogans rule
Trevor_B
Melbourne VIC
« Reply #5 on: May 27, 2004, 09:46:34 AM »
Phantom,
I had a go reworking mine. Had several significant cracks which I filled with high strength araldite epoxy. Took a couple of goes to overfill then rubbed back smooth. Then prepsol'd and undercoated with acrylic. Bit of spot filler and lots of undercoat sanded smooth then applied 17 top coats of acrylic black gloss. Polished back and looks brand new. Mind you, I haven used it on the road yet as I still haven't got a motor installed yet.
Trevor_B
Phantom
« Reply #6 on: May 28, 2004, 05:30:18 AM »
Trev it looks immaculate, did you restore the horn button as well? if you did you can do mine
                                              Cheers Rusty
Bogans rule
Trevor_B
Melbourne VIC
« Reply #7 on: May 28, 2004, 06:39:52 AM »
No Rusty,
I had a win at the last Bendigo swap meet. $10 for a complete steering column inc wheel, ring & horn button.
I fixed up the new wheel as mine was severely cracked.
The horn button probably looks better in the photo than it does in real life.
Trevor _B
Phantom
« Reply #8 on: May 28, 2004, 08:03:18 AM »
ten bucks! u sure had a big win mate, i paid 50 bucks just for the steering wheel and a crappy horn button
                             Rusty
Bogans rule
Emu
Emu's Ashes pic - Aussies 5-0
« Reply #9 on: May 28, 2004, 06:19:38 PM »
Trev,
How much do ya want  to do "Hilda's" wheel?  Wink
« Last Edit: May 28, 2004, 06:20:19 PM by Emu » Logged
streetneat
« Reply #10 on: May 28, 2004, 08:10:14 PM »
Hey there Emu ... I have restoring these wheels for a while now and was supplying thenm to rare spares for $165 on a change over basis. They were selling them for nearly double that!... The methods I  use are the same as above - boging up the cracks and a liberal dose of 2K .. comes up a treat and I have them fitted to the FC Ute and the FC custom. The hairline cracks have appeared and this will happen due to the nature of the original material. ...but they stay as hairline cracks.. so the trick is to start with a wheel with the least number of cracks and go from there .. let me know if you want yours done as we have to do my wifes soon as well. I have been charging up to $200 for this as the materials I use are expensive for one off wheels .. send me your Indicator stalk as well and if you want the whole coloum and I can do this for about $180 for you. Cheers streetneat
Cheers streetneat -Andrew
Trevor_B
Melbourne VIC
« Reply #11 on: May 28, 2004, 11:55:23 PM »
Emu,
Sounds like Streetneat may be a good option as I assume he lives in Qld as well? Would save on the postage down to Melbourne & back. Also he uses 2K paint which would be harder (less wear) than acrylic so would last longer and require less coats.
Happy to talk more if that's not the right answer for you.
Regards,
Trevor_B
-KIWI-
« Reply #12 on: May 29, 2004, 03:50:16 AM »
oye emu why would ewe want a steering wheel emus dont have arms remember !!!!!!!!!!!!!!
kiwi -emu exposer
Emu
« Reply #13 on: May 29, 2004, 07:45:31 PM »
Hey Streets,
Thanks for the info. I think I'll leave my steering wheel down the priority list at the mo. It needs doing, but I need to budget for the absolutely necessary on Hilda - such as rust repair.  Cry
She's slowly being cured. Will post some more shots soon.
Kiwi - at least we Emus have long legs to compensate for our armlessness. Wot u got? No arms and no legs!!
Emu
Phantom
« Reply #14 on: May 29, 2004, 08:00:46 PM »
OH OH here we go again
Bogans rule
-KIWI-
« Reply #15 on: May 30, 2004, 03:24:25 AM »
ewe call those toothpicks legs emu? Tongue Wink
ive seen more meat on a sparrows kneecap Kiss
kiwi -proportionally correct bird Wink Wink Wink
Sarge
« Reply #16 on: June 01, 2004, 09:15:31 AM »
Kiwi for once you are right
BIG NOSE
AND
BIG BUM
Kiwi - proportionally correct bird
Sarge
        0421 165 351
-KIWI-
« Reply #17 on: June 01, 2004, 06:19:30 PM »
oye sarge a bread obove the rest wot is dat?Huh?
tiptop?Huh??
kiwi -bread knowaboterer
