September 25, 2024, 11:41:31 AM *
Author Topic: Petrol cap key  (Read 3843 times)
Hewart
Holden on forever...
« on: May 24, 2004, 06:24:49 AM »
G'day guys...
When I bought my FC wagon last month it didn't come with any keys...! (which might explain why it hadn't been driven for so long)
I took the lock from the passenger door and rang throught the code to the local locksmith. Next day she dropped down some keys which fit the passenger door, tailgate, glovebox and ignition.... Grin
Problem is it didn't fit the petrol cap....:-/
Question being, should it have fitted, and if not, what's the best way to go about opening the tank.... Is it possible to pick the lock...? or do I try and break it open...?
Les...
robbzfc58
Gone but not forgotten.
« Reply #1 on: May 24, 2004, 06:35:21 AM »
hi les    no  it shouldnt fit    your locksmith may be able to get it off if she does house calls
 trev
robbzfc58
« Reply #2 on: May 25, 2004, 09:43:44 AM »
Hey Les.
Trev is correct. The locks were sold as accessories and keys did not match. If the locksmith will not pick it at home, drop the tank and take it to her. She should be able to pick it. If you try to prise it off, you will likely stuff the neck or break the back off the cap, probably resulting in half of it in the tank.
« Reply #3 on: May 25, 2004, 11:47:03 PM »
Hi Les,
I have had to get the locking caps off a number of cars without keys.
Screw a self tapping screw into the lock barrell and attach a slide hammer and gently tap it out. Shocked
Then you can open the cap by inserting a screwdriver into the the cap and turning. Wink
A locksmith can usually fix the barrell and key the lock.
Alex suggested dropping the tank but the locking cap will not fit through the body.
Hope this helps
Regards ACE Cool
Hewart
« Reply #4 on: May 26, 2004, 04:49:05 AM »
Thanks Alex and Ace...
I guess I'll see how I go getting the locksmith to call past. She lives only a couple-a-hundred metres up the road from me.... She's also after an FC wagon to do up and wants me to look out for one for her.....
Failing that, I'll revisit other ways I guess...
Les....
« Reply #5 on: May 26, 2004, 10:31:57 AM »
Hey Ace.
I did not think about that.....DOH!
Thanks for the correction.
Good luck Les.
« Last Edit: May 26, 2004, 10:33:24 AM by custom_fc » Logged
mad_ozi_hunter
« Reply #6 on: May 30, 2004, 11:11:37 AM »
gday
i have found that the keys for my house windows open many fc pet caps.cant say why, i have quite a few .if u want to give it a go tell me and ill send u one in post
m_o_h
fcwgn
« Reply #7 on: November 28, 2004, 09:56:57 AM »
I have an fc wagon and the ignition key unlocks the petrol cap
benno
