May 16, 2025, 03:50:16 PM *
Author Topic: EH horn button to FC wheel  (Read 4549 times)
mickusmickus
Brisbane, Queensland
« on: May 01, 2004, 01:10:06 AM »
Hi Guys
was just wondering if anyone knew if an EH horn button fitted the standard FC wheel.  They look far better than the FC one and I have the chance to buy one in very good condition.
thanks
MICK
« Reply #1 on: May 02, 2004, 01:57:40 AM »
They what?
Ignoring the question of taste, take yours off and line up the backs of them and see whether they are the same diameter or not.  I suspect they probably are, but the position of the locating lug might be different (I know FB/EK ones have it at the opposite end to the FE/FC one).
However nice the EH one is, being flat I don't think it will look quite right, if only because the original ones follow the curve of the horn-ring itself.  Your car tho, not mine, so you should do whatever you want.
mickusmickus
« Reply #2 on: May 02, 2004, 03:31:58 AM »
The EH horn button isnt flat it is a similar shape to the fc one.
MICK
« Reply #3 on: May 02, 2004, 04:01:01 AM »
Ahhh no, actually it isn't.  An FB/EK one is the same shape as FE/FC.  It has the Holden lion, with the southern cross around it, with either a green or blue stars and a black background:
The EH one is the same image as FB/EK, but flat with a red background and black edge:
Sounds like what you've been offered is an FB/EK one.  They fit, but upside down.  You have to file the locating lug off to make it fit on an FE/FC horn ring.
A good condition FE/FC one is still nicer (see attached image)
Hope that helps,
ACE
DOH!!!!!!!!!!!! !!!!
« Reply #4 on: May 02, 2004, 06:42:38 AM »
As RET said it sounds like a FB-EK horn button.
A EH horn button is smaller in diameter than a FC one and looks best on a EH  or EJ. Wink
Regards ACE Cool
mickusmickus
« Reply #5 on: May 04, 2004, 04:59:34 AM »
Sorry guys big mistake you are all right as usual thanks for the help anyway.
MICK
chesy
« Reply #6 on: May 07, 2004, 01:59:38 PM »
Guys, check out the rear vision mirrors in the images above ^^^
Is it just my computer, or is there a really ugly face in the top one Huh
hehehehe
I best shut up now.
