August 23, 2025, 10:32:44 PM *
Author Topic: washer bottle  (Read 2074 times)
fcee
« on: April 23, 2004, 07:10:56 AM »
 :)Hi GUYS ,my fc has washer jets fitted and has the button in the  wiper switch but the washer bottle and bracket have been removed ,any chance of finding a replacement  THANKS  Steve .
Sale Victioria
« Reply #1 on: April 23, 2004, 07:48:38 AM »
Hi Steve,
I've got one for sale Wink
Phone ACE  Cool   0427 430044 After 7.p.m.
« Last Edit: April 23, 2004, 07:49:54 AM by ACE » Logged
fc4kiwi
crusin fine in a "59"
« Reply #2 on: April 23, 2004, 08:43:16 AM »
hi guys could someone please post a picture of the washer jets so i know where they go ( may put some on my car) Grin
very handy items to have Cool
« Reply #3 on: April 24, 2004, 01:05:51 AM »
I haven't got a picture of them handy for you, but the original ones are fitted into the base of the wiper arm itself.
The squirter is a sort of cone-shaped affair, maybe 5/16" across, with a threaded section at one end and a pin-hole in the side of the top.  The top of the 'cone' has a hexagonal head. (Will you recognise one if you see it from that description? Roll Eyes  It's reminiscient of the screw-on fitting at the end of a capuccino frother on an espresso machine!)
So if you had ever wondered why there is a little grub screw in the wiper arm base, well now you know.  The underside of the base unit has a metal tube attached to it that runs up to these tiny squirters.  You attach the water hoses from the pump to these tubes.  Note that all wiper bases have these, there wasn't a different base unit required for the accessory washers to be fitted. (Unless of course they've since broken off...)
There are also some original after-market types that screw through a single hole in the centre/rear of the bonnet with twin squirters coming out of either side of it.
Hope that helps,
fc4kiwi
« Reply #4 on: April 24, 2004, 07:53:32 AM »
thanks for that info on the washer jets Cheesy
I was wondering at the time when i was rebuilding my FC  what the reason for the little tubes on the bottom of the wiper units were there for Huh
I think I may mount some washer jets on my windscreen vent, don't really want to drill a hole in my bonnet Roll Eyes
Page created in 0.027 seconds with 20 queries.
