September 09, 2025, 11:45:06 AM *
Author Topic: GEARBOX MOUNTS ???  (Read 2860 times)
Blown_FC
« on: April 08, 2004, 11:53:30 PM »
I have a trimatic fitted to a red motor 202.
I have also just bought the CRS Chassis kit, and noticed the crossmember that supports the gearbox, has mounting holes at a different width apart than the holes on the neck of the trimatic....
I'm presuming there would be a rubber block type mount that fits between the neck of the trimatic and the chassis kit crossmember, but as my car has been stripped for so long, I forget what it used to look like.
Can anyone post pics or explain how to mount the gearbox properly ?
Mark
FC-V8
Not enough hours in the day
« Reply #1 on: April 09, 2004, 02:05:34 AM »
Mark
        The two holes on the gearbox crossmember should be closer together than the holes on the box.
Glenn
0401-065-201
Blown_FC
« Reply #2 on: April 09, 2004, 02:46:38 AM »
That's right Glen....but why.....and how do the two bolt together if the holes are not aligned...it seems as if there should be a mount between the two....that is my question ?
Mark
ACE
DOH!!!!!!!!!!!! !!!!
« Reply #3 on: April 09, 2004, 03:03:45 AM »
Hi Mark,
The rubber gearbox mount has 2 holes in the top of it to bolt to the gearbox extension housing and 2 studs which are closer together at the bottom to go through the gearbox crossmember and are secured with nuts and washers.
Hope this helps Wink
Regards ACE Cool
« Last Edit: April 09, 2004, 03:07:16 AM by ACE » Logged
Blown_FC
« Reply #4 on: April 09, 2004, 03:05:48 AM »
Thanks Ace...that's what I was hoping to hear....do you know where I can get one of these rubber mounts...hopefully new Huh
Mark
ACE
« Reply #5 on: April 09, 2004, 03:17:38 AM »
Mark,
I would think that most spare parts shops would still stock the gearbox mounts. From memory the 3 and 4 speed Aussie gearboxes have the same mount, so if you have to buy a 2nd hand one anything from HK-VK Commodore with those gearboxes should fit. Some later model ones are reinforced with a extra bracket too. Shocked
Regards ACE Cool
Oh yeh VL V8 as well Wink
