July 16, 2025, 08:05:04 PM *
Author Topic: motorise vent  (Read 3847 times)
fc4kiwi
crusin fine in a "59"
« on: March 25, 2004, 06:36:45 AM »
has anyone done a motorise vent instead of pushing down the handle that sit under the dash,if so could someone throw a picture or drawing at me, as im in the mode to build a new dash and dont want that handle hanging down below.
« Reply #1 on: March 25, 2004, 06:53:59 AM »
It's an interesting idea - I've never heard of it being done. Its more common to see the vent welded up on modified cars.
I would think it should be straightforward enough to do.  Once you get rid of the handle - "look at the handle" Grin - you've also gotten rid of the three bump stop positions, so it should open and close smoothly with a electric window motor or similar.
Phantom
« Reply #2 on: March 25, 2004, 07:01:32 AM »
G'day all,
                   Ret why do they weld up the vent on modified cars , mine is welded up and then bogged and it looks shizenhouzen, Trev if you are still out there hoe is my cowl coming along?
                                            Cheers Rusty
Bogans rule
robbzfc58
Gone but not forgotten.
« Reply #3 on: March 25, 2004, 09:48:02 AM »
russ if i go near it with an angle grinder at this time of year i'll get shot....farmers are funny about having their farms burnt out
           cheers trev
 ps  motorised vent sounds lioke a nice novel idea
robbzfc58
« Reply #4 on: March 25, 2004, 10:20:16 AM »
Well I've never done it myself, but it's my understanding that the vent usually goes because the linkage and/or handle gets in the way of something being fitted under the dash, such as air-conditioning.
Or because it's a permanent way to stop the thing leaking Roll Eyes
« Reply #5 on: March 25, 2004, 11:03:15 AM »
Why not use a pop-up headlight mechanism from a VL Calais or an RX7 or similar? The Galaxie I have down the back uses a vacuum arrangement, hmmmmm.
You guys, stop giving me ideas!
« Reply #6 on: March 25, 2004, 11:24:53 AM »
This idea is not a new one. There are a few Hot Rod suppliers in the USA that offer a kit for this modification.
Here is one showing the basic components.
Here is a link to their site.
http://www.julianos.com/power_cowl_vent.html
Here is a different set up.
The link to this site.
http://www.hotrodsusa.com/buynow/manufactures/balls/cowl.htm
It might be worth a phone call to your local Hot Rod parts store to see if they import a version.
« Reply #7 on: March 25, 2004, 10:01:21 PM »
Cool idea, but not so good  if space saving was ur primary motivation. (hard to obtain scale on those pics)
I love modifiying my FE, but of the few things always destined to stay.. the vent handle was one of them!  I love it and  went to lengths to repair it.
Im using my cowl vent to cool my ignition module.. sneaky huh.
« Reply #8 on: March 26, 2004, 01:59:10 AM »
Hi Guys,
This is something I also had a look at while doing  the van... There is a company up here that repairs the hydraulic/gas struts that I have used for the tailgate, they also supply a hydraulic ram that you can set up certain positions of actuation. This unit is small enough to do the job of the 3 position lever that the FC/FE has, but from memory it was about $350.00, so I made the centre console around the original handle.
There would probably be a supplier of the same things down your way.
Jason.
Page created in 0.048 seconds with 21 queries.
