July 21, 2025, 09:12:26 PM *
Author Topic: engine running rough  (Read 1575 times)
none@unknown.net
« on: February 27, 2001, 01:00:00 PM »
the grey in my FC ute runs okay on idle but when held above idle it shakes and sounds like it is missing. I have checked leads, changed plugs. coil and breaker points. I was wondering if anyone else has had the same problem and is able to tell me what might be wrong. Ps I am geting withdrawal symptons form not being able to drive the old girl.Thanks kindly Dave.
bryan
« Reply #1 on: February 28, 2001, 01:00:00 PM »
hi there,with the engine running rough you have replaced the points did you replace the condenser as tese do breakdown.if you have replaced it make sure it is of the same capacity as the old one.also check that vacum lines are secure.if you have an intake leak this will upset engine performance.i hope this is ahelp good luck on your fc.
Page created in 0.024 seconds with 19 queries.
