August 19, 2025, 04:19:23 PM *
Author Topic: FC Ute Rear Spring Pack Identification  (Read 1093 times)
Jolls
« on: June 23, 2025, 07:46:31 PM »
Hi Team,
I am trying to identfy the origins of this spring pack for my FC ute project.
I removed it from the ute. It has six main springs as shown in the manual and it mounts in exactly the same manner; however, there are two addtional bottom springs. The additonal springs have metric nuts bolts and the pin thread is also metric so I expect that the original springs were replaced with an aftermarket option. Can anyone help in identifying what I have?
Cheers n Beers
Jolls
Cheers n Beers
Jolls
Jolls
« Reply #1 on: June 25, 2025, 08:30:45 AM »
After some digging and supprt from Rob I think I have identified the spring setup. The leaves are 2", not metric, in both the six leaf pack and the addtional two. The six leaf pack appears to be an original set from a ute/wagon as they are tapered and rounded and look identical to what is shown in the FE/FC manual.
The addtional two bottom leaves do not taper and have square ends with rounded edges. The pins and bolts holding it all togehter have been replaced with metric ones - potentially by the previous owner who had started the restoration prior to his passing when the ute was put back into the shed for another twenty odd years.
It had been suggested to me that they may be lowering springs that were used instead of blocks. However, when I pulled the leaf pack apart it didn't take much effort on the clamp to pull the leaves in to undo the bolts; so  I don't think that they were performing a lowering function.
My theory from the design was that they were overload springs but none of my internet research privided any leads. I had previously searched the forum but couldn't find any related info but went back and searched the Accessory of the Week thread and I found this reference to Rogers Overload Shock Absorber Leaves.
. You can find the full post here: https://forum.fefcholden.club/index.php?topic=13115.msg78351#msg78351
So it looks like it is a set of standard ute leaf springs that have been "uprated" to constant load springs with the addtion of two overload leaves at the cost of 7 quid back in the day. I have been tossing up the benefit of removing them to lower the unsprung weight and improve her handling v's keeping them as part of her history.
I have decided to clean them up as found, give them a coat of paint for protection and replace the wear pads and bushes and put it back together. My old girl will probably not be carrying anthing more than a picnic table, a couple of fold up chairs, an esky and a couple of bags in her old age, but the overload springs will be an acknowledgement to her working life.
Cheers n Beers
Jolls
graham_fuller
« Reply #2 on: July 02, 2025, 03:40:46 PM »
Hi Jolls,
I had a set on my FE sedan when the springs sagged a bit. They were helpful and also appeared stop some body roll as well. They were also called uplift springs.
Jolls
« Reply #3 on: July 02, 2025, 08:12:33 PM »
Hi Jolls,
Thanks Graham,
Just finished refurbishing them - replaced the spring liners, rubbers and bolts - repainted in orange (had it on hand) so they are good to go back in.
Cheers n Beers
Jolls
Page created in 0.025 seconds with 19 queries.
