August 27, 2025, 12:05:27 PM *
Author Topic: Gear box overhaul kit.  (Read 2275 times)
fastjbav6
OK start her up !
« on: February 18, 2025, 12:49:00 AM »
Hello Guys,
Where is the best place to buy crash box overhaul kit these days?
Rare Spares are selling for just under $320 and none available in WA.
Muscle & Classic Parts in Campbellfield VIC 3061 are selling for just under $196, same part number 7430864 as Rare Spares.
Haven't purchased a kit in over 30 years.
Regards Seb
Yellow Knight
« Reply #1 on: February 18, 2025, 11:02:32 AM »
Availability is a problem.  One thing to check, though, is whether the overhaul kit has a single or double row mainshaft bearing.
The last couple of times overhauled a grey gearbox, I re-used almost all the original parts.  One gearbox needed a cluster gear and first-reverse gear; the bearings and shafts were good to re-use.  In the other gearbox the mainshaft bearing started to growl, and I replaced the original single-row bearing with a good, used double-row bearing.
I've heard that the double-row mainshaft bearing is also used in a Mitsubishi L300, except that the Mitsi bearing has no circlip groove in the outer race (would need to be machined).
Places like CBC Bearings (or Coventry perhaps in WA) have a good cross-reference with original part numbers if either of the ball bearings are unserviceable.  But I wouldn't replace a double-row bearing with a single-row one.
The 3/4" expansion plugs for the countershaft and reverse idler shaft are standard items.  Rear extension housing and transverse selector shaft oil seals are also available separately.
« Reply #2 on: February 18, 2025, 02:17:21 PM »
Rob is right, most of it is reusable. Gaskets could be cut from sheet stock from Supercheap or similar. Some random parts if you want to make a go:
Selector Shaft Seal (NAK Australia)   E062.100.25
Gasket Set Grey Gearbox FX-EK (Rare Spares)   7405896
Front Propeller Shaft Housing Seal (Rare Spares) H1067 or (NAK Australia) E137.206.25
Ball bearing (UBC Australia) 6206RSNR or (NTN Toyo Bearing Co) 6206NR
Ball bearing (UBC-Australia) 6205RS or (NTN Toyo Bearing Co) 6205NS
fastjbav6
OK start her up !
« Reply #3 on: April 11, 2025, 01:36:45 AM »
Thanks for the info guys.  Put a 2nd hand unit in until I can overhaul it.
Yellow Knight
Page created in 0.024 seconds with 19 queries.
