September 06, 2025, 09:34:33 AM *
Author Topic: How to dismantle internal sun visors?  (Read 2476 times)
oldgrey58
South East Melbourne
« on: February 07, 2024, 10:54:16 AM »
Could anyone assist to tell me how you take apart the internal sun visors including how the visor part is removed from the rod.
Sent from my SM-S9060 using Tapatalk
DougT
« Reply #1 on: February 07, 2024, 12:55:42 PM »
I have recently had to do this. Firstly you will have to remove the bunding by cutting the stitching then the vinyl covering will be able to be removed. Inside you will find a masonite type board that is stapled to the metal sleeve that runs the length of the rod. I found the staples to be made of quite tough metal; however, I was able to straighten and reuse them in order to refix a replacement board (old one had broken away from the sleeve). The sleeve is held in place by what I can only describe as an interference fit on the rod and should be able to be removed by rotating the rod while trying to pull it from the sleeve. Hope this helps Doug
oldgrey58
« Reply #2 on: February 07, 2024, 10:36:16 PM »
Thanks Doug, much appreciated.
It also looks like the rods need to be ground down so that the chromed mounts can be removed and then the rods re-peened over to reinstall.
Jolls
« Reply #3 on: February 08, 2024, 05:29:12 AM »
That is my understanding of how the mounts are removed. I have it on my list to do.
Jolls
Cheers n Beers
Jolls
