July 14, 2025, 08:56:09 AM *
Pages: 1 ... 6 7 [8]   Go Down
Author Topic: Jolls FC Ute Project  (Read 28527 times)
Jolls
« Reply #140 on: July 02, 2025, 10:32:24 PM »
So today I completed the leaf packs - new bolts, spring liners and a lovely orange rustoleum finish (Wests Tigers underbody colour scheme  Cheesy) The front springs have been rubbed back and repainted to match.
The old girl is now completely stripped less the wiring from the cab to the tailights. I have left them in place so I can pull a draw wire through next time I am out there. The wiring harness is missing a few components so I will need to do an audit on the harness to order the missing components and cables in the right colour schem. That will be a fun task! As it was a commercial vehicle I will need to add the missing bits that I will be adding:
  • Reverse lights
  • Radio
  • Cigar Lighter
  • Dome light switches
  • Brake Warning Light
  • Glove Box Light
  • Ignition Switch Light and
  • Indicators (including converting the brake light indicator to a combination reverse (white) and indicator (orange) LED
I bit the bullet and purchased a rotisserie for this build - why I didn't fork out the $ previouslyis beyond me. It is so much easier to work on.
I think I spun her around a dozen times to get most of the dirt and dust out. It is still coming out of the rails so I will need to get some air/leave on rust converter and fish oil in them.
Found some addtional rust under the cowl - not too bad and identifed some "bog" based panel damage repairs just behind both doors - so I will have to sand out the bog, beat the dents out a little prep for paint. The rest of the body is straight. I identified a little more rust to be repaired but pretty straight forward repairs. The most challenging being aroudn the fult tank. the POR is in the post so I will get some fuel rated JB weld to deal with any pinholes I find.
I found that there wouldn't have been room to pein over solid rivets in the fuel sender. I have riveted it using blind rivets with a standard gun and will seal the rivets with POR to prevent leaks.
Progressing slowly but surely!
Cheers n Beers
Jolls
« Reply #141 on: July 03, 2025, 07:28:35 AM »
Jolls  ..I had to clean out the fuel system on a fire fighting pump , left in a shed for ages and probably had E10 fuel go dry ...Citrus based paint stripper , can't recall the brand , but it was in a orange coloured tin , did a brilliant job ... Vern ..
Jolls
« Reply #142 on: July 03, 2025, 10:26:40 AM »
Thanks Vern,
Great tip - I think I know the one you are referring to. Will give it a crack while I'm wating for the POR to arrive.
Cheers n Beers
Jolls
Jolls
« Reply #143 on: July 11, 2025, 05:14:55 PM »
So where are we up to:
I had rust in 2/3 of the lip around the fuel tank that was beyond saving. I was in the process of doing the research to purchase a bead roller so I could make a replacement. I had thought about it overnight and was going to place an order late last week when I wandered past a damaged door from Son 2's VZ crewman project. I noticed that it had a moulded line down in the middle of the door. It looked close to the lip I needed to create in the rusted sections I had to cut out. I cut it out the section with a grinder and hey presto; almost identical form.
That was the inspiration I needed. So armed with a grinder and some cutting discs I went to work on the rusted sections, leaving the reinforced corners so I had something to weld to. I tacked in the straight bits in then sliced some smaller sections through the back so I could bend them to the corner profiles and tacked them in. Once that was done the back of the curved sections were reinforeced and the missing wedge sections plug welded. Back then to finishing the welds on the new lip and one major job completed. From there I plated some rust sections in the rear floor. I still need to go back and plate them from the other side and weld a couple of rusted flange sections of the cross member in place. All in all happy with the progress.
Prepping the cam to go off and be reground I found one of the cam followers was damaged - so I am on the hunt of a replacement (just one). The one I require is to suit a 10 5/16" pushrod. The intenal depth of the lifter is 1 13/16" (1.852"/47.04mm) as opposed to 1 5/8" on the later version. I have posted on FB chasing a replacement - but if you have a spare handy I'd be happy to part with a few beer tokens.
Prepping the engine to go off for a refresh and I found that the oil pressure relief valve in the oil pump was rusted in place. With some advice from Rob I set out to extract it using a a nut and bolt by cutting a thread into the internal of the valve and then using a nut to extract it. The process itself failed but in cutting the thread the valve came loose and I was able to remove it. I need to purchase a new 9mm tap to replace the damaged one but at least the oil pump was saved from the tip.  I ordered an oil pump rebuild kit from Auto Surplus (was cheaper on ePay than it was on their site - unusual).
So the motor is now good to go to the machine shop to be inspected and we will make a plan for the refresh once we know what needs to be done. The concept at the moment is to up the compression a little, what size slug and from where will depend on the assessment of the block, shave the head a little and machine it to accept 202 valves. I was thinking of lightening the flywheel a bit but have scrapped that idea as I plan to run a .355/.336 diff centre and the mass will be helpful there. I have a set of twin strombergs and triple SU's to handle the fueling side of the house, no decision on which solution as yet, and the extractors have already been purchased.
The king pins are in being done so that is the start of the steering refurb.
POR arrived during the week so next on the list is to seal the fuel tank and get back to work on the rust issues and reinforcing the floor pan for seat belts. I'm not going to fit the seat belts until after I get the old girl registered to save on having the engineer the whole setup.
Cheers n Beers
Jolls
« Reply #144 on: July 12, 2025, 08:44:50 AM »
Go the SUs Jolls, you won’t be sorry. As long as the throttle shafts are in good condition, floats, needle and seats and new jets and hopefully already got the right needles and springs for your tune, they are simple, robust and efficient.
« Reply #145 on: July 12, 2025, 06:39:26 PM »
Craig,
A.t.m. I only have the later cam followers.  But the service note says you're OK to use them in the earlier engines if you use a late follower with a short pushrod.
If you have no luck finding an earlier follower I'm happy to send you a late follower plus short pushrod.
Jolls
« Reply #146 on: July 12, 2025, 07:06:57 PM »
The SUs are in good condition and I am fortunate to have a good friend who has a business restoring carbs a few of properties over. I was keeping hold of the twins just in case there is an issue in getting her past the initial blue slip. Not sure how that would be viewed.
Once finished she will be a "work ute" in the excavation side of our business. Work as in mobile advertising!
This is the first draft of the advertsing concept - not done by me. It is a bit over the top. The Scooby mobile swirls and the modern book now thing will defeintely not get a run and the writing will be less over the top but you can get the gist.
Cheers n Beers
Jolls
Jolls
« Reply #147 on: July 12, 2025, 07:08:02 PM »
Craig,
Thanks Rob, I appreciate the offer. I think I have secured a couple of the right followers on their way on Monday.
Cheers n Beers
Jolls
« Reply #148 on: July 12, 2025, 08:28:02 PM »
Craig,
I just read your post in "Parts Wanted".  Cam follower with a piece missing from the side . . .
So your engine had a stuck valve at some point.
You'd be surprised how many grey motors have cam followers with pieces missing from the sides.  Doesn't affect how the engine runs at all.
Check pushrod carefully to ensure it's not bent; or that it has been straightened successfully.
Jolls
« Reply #149 on: July 12, 2025, 08:49:17 PM »
Craig,
Hi Rob,
Thanks, yes checking pushrods and the lifter bore for damage.
Craig
Cheers n Beers
Jolls
Pages: 1 ... 6 7 [8]   Go Up
