June 18, 2025, 12:36:15 AM *
Author Topic: Fitting new oil seal to dizzy  (Read 1530 times)
Wookie 66
« on: May 07, 2021, 09:33:03 AM »
Good morning
I can’t find any info on fitting a new dizzy oil seal I bough on of the after market ones and the dizzy doesn’t seem want to drop in that last little bit
The seal that came off seemed wider though it was flat and hard as a rock
The new one seems thinner
Any tricks I’m missing ?
Any advice appreciated
« Reply #1 on: May 07, 2021, 09:48:26 AM »
Grease the seal well, and push down hard on the distributor body.
Online Online
« Reply #2 on: May 07, 2021, 11:47:03 AM »
... and when that doesn't work, spend a few hours checking measurements, turning the oil pump via a screwdriver, turn the engine back and forth one cam tooth repeatedly, try another distributor, retry the old distributor, then get frazzled and call a mate for advice. Have the mate regrease and lean really, really hard on the dizzy body (without busting anything fragile on or under the cap) until it drops in. Thank him.
... don't ask me how I know  Embarrassed (and thanks again Rob).
Wookie 66
« Reply #3 on: May 07, 2021, 12:06:23 PM »
I get the idea now was not sure how much pressure to put on before I broke something else that I had to buy a new one
Pss
I don’t have any mates, well my son in law is a mechanic I’ll get him to look at
Though he’s not very good unless it connects to a computer then he’s brilliant.
