July 29, 2025, 01:58:08 AM *
Author Topic: steering wheel removal  (Read 6658 times)
fcee
« on: February 17, 2021, 10:28:22 AM »
   Was a puller ever available to remove fc steering wheels to avoid the brute strength method ,or maybe a modern one to do the job .cheers  Steve. Wink
Sale Victioria
« Reply #1 on: February 17, 2021, 10:55:37 AM »
Yes there was.  The puller had two L-shaped legs that went in through the oval holes in the steering wheel hub.  You turn them a quarter turn to engage behind the hub, and then pull the steering wheel off.
Grinding most of the head off hex-head bolts works, sort-of, but damages the steering wheel.  It's best to weld more material onto the bolt head so the bottom of the "L" only just fits through the oval slots.
old-blu
« Reply #2 on: February 17, 2021, 11:01:18 AM »
 Hi Steve. The removal tool is part No. 1606, COXHEAD STEERING WHEEL PULLER ,[to suit HOLDEN]. The one shown here has FE stamped on one side.
.  I bought this one @ a swap meet back in "the dark ages".  removal is easy. Good luck. Kevin.
6th, may 1958 "I was there".
old-blu
« Reply #3 on: February 18, 2021, 10:51:00 AM »
 While I looking through my shelves:   Here are 2 other TOOLS needed for restorations.   Top:  Camber adjusting LHS & RHS.
        Bottom:  Harmonic Balancer removal [ stamped Hitchfield E 1103   6A-1 ]
    Also pic from Manual showing removal tool in place.   Kevin.
fcee
« Reply #4 on: February 18, 2021, 07:18:15 PM »
   Thanks Rob and Kevin ,purchased a puller at supercheap and modified the bolt heads to fit the wheel slots ,works great ! cheers Steve . Wink
Sale Victioria
my8thholden
« Reply #5 on: February 19, 2021, 08:19:48 AM »
fcee ..What is part number of Super Cheep Cheep puller you purchased and modified ?
fcee
« Reply #6 on: February 19, 2021, 02:34:51 PM »
   Vern ,the puller is a blister pack ,number on pack plu12549 code gshf0324 ,it is bolt type puller with six bolts supplied ,2 of the bolts have larger heads ,by grinding three sides off these and to the shape of the wheel slots neatly, once inserted can be tuned 90 degrees to engage the  hub ,sure you will work it out ! let me know how you go .cheers Steve  Wink cheep too .
Sale Victioria
my8thholden
« Reply #7 on: February 20, 2021, 06:48:36 AM »
thanks mate , i'm on to it ..Vern
