August 06, 2025, 05:28:00 AM *
Poll
Question: Any photos of front drivers break lines
1 -
0 0%
2 -
0 0%
Total Voters: 0
Author Topic: Front drives break line  (Read 1939 times)
Wookie 66
« on: November 15, 2020, 01:05:33 PM »
Hi all help
Im having a mental block can’t find my deconstruction photos
Any one have a picture of the front drivers break line there’s something I’m missing
Have the brass block with the passenger side connected and master cylinder connected and rear
Leaving the front drivers side no where to go?
« Reply #1 on: November 15, 2020, 01:28:04 PM »
Trevor,
The brake line distribution block has four holes for brake pipes:  one in the top (master cylinder), one at the rear (for the rear brakes), and two holes at the front: left and right front brake pipes.
Have you got the right one?  It has a tab and bolt hole on the right side to mount on the front subframe RH outer leg.
The distribution block for the rear axle only has three holes, and no mounting tab.
« Last Edit: November 15, 2020, 04:04:24 PM by ardiesse » Logged
« Reply #2 on: November 15, 2020, 04:12:29 PM »
Seen from the front:
Seen from the rear:
Wookie 66
« Reply #3 on: November 16, 2020, 06:45:47 AM »
Hi Rob
Well that’s just embarrassing I put in on upside down
Thanks for the photo
my8thholden
« Reply #4 on: November 16, 2020, 08:04:55 AM »
The bloke that hasn't made a mistake ,hasn't made anything ...Vern
Page created in 0.031 seconds with 22 queries.
