August 14, 2025, 04:54:16 AM *
Author Topic: Fuel Tank Repair  (Read 2917 times)
abletec
« on: May 27, 2020, 07:44:53 PM »
The fuel/petrol tank in my FC wagon is very dented but quite solid. I have started to remove the dents and it is coming up quite well. I have a question in that it has one particular side dent in the corner diagonally opposite the fuel filler pipe. It looks like it is factory pressed so don't know if I should remove it. Can anyone please tell me if all four corners should be basically the same or does one have a side pressing. I haven't got access to my wagon to see if there is a reason for the dent/pressing. I think a wagon van or ute would have the same fuel tank. Thanks.
« Reply #1 on: May 27, 2020, 08:42:50 PM »
Wagon, van and ute all have the same tank body, just the filler necks vary slightly between ute and wagon at least so I believe. There aren't any non symmetrical pressings and all the four corners and sides are identical.
« Reply #2 on: May 28, 2020, 08:37:06 AM »
All four corners of the tank are completely identical, no pressed in sections.
Wagon, van and Ute tank are all identical including filler neck.
« Reply #3 on: May 28, 2020, 08:52:58 AM »
Makes sense about the filler neck Ken. I was thinking of FB wagon I suppose, not FE FC.
