May 19, 2025, 08:03:48 PM *
Author Topic: GMB’s Daily - Quick Tidy Up  (Read 10980 times)
GMB-58FC
Stage one complete...
« on: April 28, 2020, 02:09:00 PM »
Was using the car as my daily until a few weeks ago when we were going to put a new seal & gasket kit through the motor as the rear main was leaking quite bad from sitting around for 10 years with minimal use.
Motor out and found we had a faulty water pump and broken thermostat housing so decided to pull the motor down to be safe.  Turns out it had never been opened and in amazing condition.
Motor is currently with the machine shop and he was shocked that it had never been opened and all as it was from factory including the plastic timing gears.
It’s getting a quick once over and will be rebuilt to  XU1 spec with the head tickled and will try and source a 390 Holley set up for it.
In the mean time I’m I’m tidying up the engine bay and a few small areas on the car during this isolation & unemployment period so I don’t go stir crazy!!!
Before shot:
Quick elbow grease clean:
Not sure if I want to open the can of worms and cut the small sections of rust out of the guards & doors or just leave it be for now.
Need to replace all door seals and belts, front & rear glass rubbers, boot & bonnet seals etc
Interior needs some love and have already started tidying up the wiring harness and need to work out why the speedo stopped working just before I pulled it off the road.
I will make sure I update with more progress shots soon.
ABS Hobart- 6231 5855
PM FOR QUOTE
« Reply #1 on: April 28, 2020, 02:19:35 PM »
Just a quick tidy-up?
I'm willing to bet it'll turn into a paint job.
GMB-58FC
« Reply #2 on: April 28, 2020, 02:31:29 PM »
No paint job, just a tidy up.  If I repaint the car it defeats the purpose of keeping it a little old & ratty as it currently sits.
No point going to crazy with mods/upgrades as id more than likely have to then have it engineered and defeats the purpose of what I’m trying to achieve with it.
PM FOR QUOTE
GMB-58FC
« Reply #3 on: May 05, 2020, 11:10:12 PM »
Found a set of 13x8” steelies that need some love but should come up sweet when I’m finished.
PM FOR QUOTE
camxsmith
« Reply #4 on: May 06, 2020, 07:56:28 AM »
Wow nice find
« Reply #5 on: May 06, 2020, 08:22:30 AM »
You going to bring the chrome back or too far gone? They’ll be tight but look nice.
« Reply #6 on: May 06, 2020, 08:59:02 AM »
better get the steering geometry manual out  ..
GMB-58FC
« Reply #7 on: May 07, 2020, 03:19:47 PM »
Chrome is too far gone sadly so will get them blasted/cleaned up and a lick of paint/clear and they will do the job for now.
I got a lead on a pair of 13” dress rings today so hopefully it comes good.
PM FOR QUOTE
GMB-58FC
« Reply #8 on: January 28, 2021, 10:27:01 AM »
A little over 6 months and we have some progress again with the motor starting to take shape.
I think my daughter will be an only child... 🤣
Motor should hopefully be back together next week ready to test fit and then tackle the wiring mess under the bonnet along with a few other items that need some TLC.
PM FOR QUOTE
GMB-58FC
« Reply #9 on: February 02, 2021, 06:59:44 PM »
Waiting on the final bearing required to rebuild the 3.08 centre and have my 3.55 LSD now for sale.
Trial fitting these tomorrow
Have the following kit to install next week
PM FOR QUOTE
« Reply #10 on: February 04, 2021, 11:10:00 AM »
Oh my I think I need a set of those I don't think you should have shown that photo mate  Grin Grin
Neil
« Reply #11 on: February 04, 2021, 04:43:43 PM »
will power is tested by temptation ...Vern ..
GMB-58FC
« Reply #12 on: February 16, 2021, 03:39:25 PM »
Motor painted and ready to test fit once the carb set up is finished.
PM FOR QUOTE
GMB-58FC
« Reply #13 on: March 12, 2021, 03:49:04 PM »
For a “bolt on” part these manifolds are bloody terrible.  Lots of work to get these to slip on & off and be able to nip up a bolt.
Quite poor for something that isn’t exactly “cheap”
PM FOR QUOTE
GMB-58FC
« Reply #14 on: April 19, 2021, 11:13:58 PM »
PM FOR QUOTE
« Reply #15 on: April 20, 2021, 11:28:57 AM »
A very neat-looking setup.
But I'm curious about the red-motor-mounted, disc-braked FJ front suspension in the background.
GMB-58FC
« Reply #16 on: April 22, 2021, 01:08:07 PM »
Removed from another project to be upgraded to a USS front end.
PM FOR QUOTE
GMB-58FC
« Reply #17 on: November 03, 2021, 02:47:50 PM »
Things have been a little slow with progress due to life getting in the way but decided to have another crack and get it back on the road for summer festivities.
Firewall notched:
One lick of primer:
PM FOR QUOTE
GMB-58FC
« Reply #18 on: June 03, 2022, 06:12:45 PM »
All wiring finished, cam run in and carbs are set.
Just have to sort out a pedal/throttle cable set up and it’s back on the road 😈
PM FOR QUOTE
