my8thholden
Offline
« on: January 13, 2020, 07:20:46 AM » |
hello all ..I need front drivers upper door hinge,complete with good hinge pin and keeper spring ..( half of spring has broken off on mine )can reply here or mobile 0405 703 413 ..THX Vern
« Reply #1 on: January 13, 2020, 10:18:12 AM » |
Vern,
Not certain, but I think Rare Spares sells rebuild kits for the front door hinges, with pin, bushes, rivets and springs. The spring is the same all the way through to HR.
My experience is that the front door hinges are individually fitted to each car, and you run the risk of the door not aligning properly if you replace them.
« Reply #2 on: January 13, 2020, 10:40:16 AM » |
I confirm you can get the springs and rivets at least. I’m not sure about the pins.
JOX515
Offline
« Reply #3 on: January 13, 2020, 05:46:27 PM » |
pm me your address Vern and I will send you up my spare set of spings, pins, bushes and rivets - not needed here anymore. Cheers, Graeme
my8thholden
Offline
« Reply #4 on: January 14, 2020, 06:35:50 AM » |
Gentlemen ..Thank you,I was not aware of a repair kit ,so I will PM you Graeme ..cheers Vern ..
my8thholden
Offline
« Reply #5 on: January 29, 2020, 07:37:55 AM » |
Greame .I sent you a PM on 14th,you were looking for a piece of the door hinge spring kit ,any luck yet ? ..thanks Vern ..
JOX515
Offline
« Reply #6 on: January 29, 2020, 08:00:08 AM » |
No luck yet Vern but will send up what I have and will send the other spring if it turns up. Cheers, Graeme
my8thholden
Offline
« Reply #7 on: January 29, 2020, 08:17:48 AM » |
Ok thx ,not much happening here ,too hot and humid ,cant wait till autumn ..look forward to post ,I owe you ..Vern ..
JOX515
Offline
« Reply #8 on: February 05, 2020, 05:13:47 PM » |
Goodies are on their way finally Vern
my8thholden
Offline
« Reply #9 on: February 06, 2020, 08:16:50 AM » |
Thanks Graeme ..I'll look forward to it ..I said here not much happening ,sorry ,I meant over the festive season ,we are back into it ,see under restoration sect ..we hope to paint doors today ..Vern ..
my8thholden
Offline
« Reply #10 on: February 12, 2020, 07:24:34 AM » |
Greame ..Haven't seen parcel as yet ,I assume you sent Australia Post ,is there a track and trace number you can send me ,and i'll follow up this end..thanks Vern ..
