August 20, 2025, 02:00:10 PM *
Pages: 1 [2]   Go Down
Author Topic: FC ute tailgate skin  (Read 13152 times)
waynos
patience grasshopper
« Reply #20 on: July 31, 2019, 07:09:55 PM »
if you are doing a rust repair it makes more sense to use 18 gauge because by the time youve ground down your weld on the butt weld you have less chance of paper thin metal
trust me ive fixed those problems for people
« Reply #21 on: July 31, 2019, 07:15:28 PM »
Trouble I have Wayno is grinding through the original material, not the new bit. I probably need to make my patches bigger and cut out a larger area to get good tin. If I can get behind it I will lay beads parallel to the joint on the old stuff.
waynos
« Reply #22 on: August 03, 2019, 12:27:23 PM »
you need to take off the weld trying not to hit original metal at all, untill right at the end.it takes lots of practice
« Reply #23 on: August 03, 2019, 02:42:33 PM »
Thanks. I’ll give it a try. I’ve been starting with a little build on the old bit. Shallow angle square to cut. Seems to dissipate the heat and prevent blowing through.
redminch
« Reply #24 on: August 14, 2019, 07:14:13 PM »
Nor sure if you have found the tailgate skin. I have used Ray Taylors pieces and they are good as has been said.
But Craig Venn at Rust a Problem makes good ones too.
He is up near Maryborough in Qld and easy to deal with as well.
I do not know the prices quoted but I believe that Rare Spares have theirs made by "others" anyway.
Let us know how you get on it helps to know the current status of parts suppliers.
Brian
fcute
« Reply #25 on: April 11, 2025, 12:21:02 AM »
Apologies for the delayed update I ended up using Taylor's outer tailgate skin, it fitted well.
« Reply #26 on: July 05, 2025, 03:40:30 PM »
Ray Taylor passed away a few years ago now. Did you deal with his son, or was it old stock?
fcute
« Reply #27 on: July 06, 2025, 09:42:10 PM »
I believe I was dealing with Ray I had a really nice chat with him, a very friendly fellow.
« Reply #28 on: July 07, 2025, 10:07:44 AM »
That would have been him.
Pages: 1 [2]   Go Up
Page created in 0.049 seconds with 19 queries.
