August 30, 2025, 11:06:13 AM *
Author Topic: air cons in fc  (Read 3917 times)
parry
« on: July 11, 2019, 07:23:41 PM »
Hi not wanting to start up the air con debate again just want to know if any body has fitted one and has photos so I can see or head me in the right direction if there is a thread already
Steven
REDMR2RED
FC Ute's d'best
« Reply #1 on: July 13, 2019, 03:20:49 PM »
http://www.fbekholden.com/forum/viewtopic.php?t=21007
http://www.fbekholden.com/forum/viewtopic.php?t=9817
1959 FC Holden Ute
old-blu
« Reply #2 on: July 14, 2019, 10:02:59 AM »
 This unit is a Commuter 4, commonly used in Toranas etc, back in the day. The Harmonic balancer has a dual pulley to drive the compressor, as well as the fan. A thermo fan is fitted to the front of the radiator, with a switch to the dash [ used in traffic], to avoid overheating. The under dash unit has an on/off switch as well as temp adjustment.  Works well, however, the grey lets you know when you switch it on!. The compressor is still available
6th, may 1958 "I was there".
parry
« Reply #3 on: July 15, 2019, 05:59:24 PM »
Thanks for the info I'm fitting a small block chevy so the brackets won't be a problem, I just wanted to see some interiors as I want to keep in and out looking as standard as possible do not want to cut the dash.
Steven
