April 26, 2024, 10:31:34 AM *
Pages: 1 2 [3] 4   Go Down
Author Topic: FC wagon barn find.  (Read 24280 times)
« Reply #40 on: February 08, 2018, 01:51:40 PM »
Just need to repro the little fold over lip to secure the very good rubbers Lowlife. Or have you already?
Maco
« Reply #41 on: February 08, 2018, 01:56:51 PM »
I will be taking some sets to the Nationals in Canberra.
Better in Green
Maco
« Reply #42 on: February 08, 2018, 01:58:16 PM »
And they are a good product. See more discussion here: Rear body to bumper seal available
Thanks Dave.
Better in Green
Lowlife
Raglan Vic.
« Reply #43 on: February 14, 2018, 12:37:03 PM »
G
graham_fuller
« Reply #44 on: February 14, 2018, 01:34:02 PM »
Stacks were a Holden Distributor in Sydney in the early days.
« Reply #45 on: February 14, 2018, 03:15:30 PM »
Our Standard Wagon was supplied by Stack
attached images of the folder that came with it
« Reply #46 on: February 14, 2018, 03:27:55 PM »
Here are some of the different types of Stack badges I have found over the years that Stacks were operating
Like a lot of older Holden stuff these and I suspect other badges are being reproduced and some are hard to pick
Lowlife
Raglan Vic.
« Reply #47 on: February 14, 2018, 06:14:18 PM »
Thanks for all the info guys.
Now that I know where they were, do you think they will fix all the rust under warranty 😂😂😂
Sent from my HTC 2PZF1 using Tapatalk
Lowlife
Raglan Vic.
« Reply #48 on: February 26, 2018, 08:40:52 PM »
G
VAN059
Brisbane, QLD.
« Reply #49 on: February 27, 2018, 11:27:21 AM »
Let me know how you go with the warranty submission, I've got a heap of claims I can think of  Shocked Grin
Lowlife
Raglan Vic.
« Reply #50 on: March 02, 2018, 03:03:36 PM »
G
camxsmith
« Reply #51 on: March 03, 2018, 12:36:04 PM »
I was the same when I cut mine,  thinking where to cut and what to leave..  I tried to picture the sand blaster getting access to all the inners. I think that's the best idea.  I also thought it would be a little more ridged when travelling the more you leave on there...     But when it comes down to it.. the new sill requires you to remove back to spot welds top and bottom...
I would also recommend taking as much of that black seam sealer off as you can. Does not have to be perfect, just the blast struggles to move the big lumps. Especially in the rear quarters behind the rear wheels. As my blaster did not take that back to the metal  and I have found rust does grow under it... Undecided Undecided
Lowlife
Raglan Vic.
« Reply #52 on: March 03, 2018, 02:09:55 PM »
Thanks cam. Same train of thought here, I know I'll need to cut more off later but thought it'd be best wait til after the blasting.
Lowlife
Raglan Vic.
« Reply #53 on: March 03, 2018, 02:12:24 PM »
G
« Reply #54 on: March 03, 2018, 05:06:56 PM »
I would cut as close as you’re comfortable to the inner sill, leaving the turned up lip on top and flat spot welded strip on the bottom. Then grind out the spots on the bottom and peel off. Cut off the top lip horizontally and grind out the spots again on top. You may want to avoid cutting through the turned up edge of the floor panel when you do this, depending on what is left of it and whether it is welded to the outer sill lip. Then  you can assess the inner and clean up or replace. Take care around the A, B and C pillar bottoms of course which you are best to attack cautiously bit by bit with the grinder. Just my 2c worth.
Clay
Lowlife
Raglan Vic.
« Reply #55 on: March 16, 2018, 01:26:38 PM »
G
Lowlife
Raglan Vic.
« Reply #56 on: March 16, 2018, 01:27:17 PM »
G
GMHwagoon
« Reply #57 on: March 16, 2018, 01:38:03 PM »
 no never seen repo ones   but lm sure someone will have spares
 l will have a look tonight
                                      fcwagoon
« Reply #58 on: March 16, 2018, 05:34:17 PM »
How good a shot with a welder are you?  I figure it's easier to repair what you've got . . .
« Reply #59 on: March 17, 2018, 12:49:49 PM »
. . . and then I just discovered a pair of them.  Would you like them?
Pages: 1 2 [3] 4   Go Up
Page created in 0.036 seconds with 21 queries.
