August 15, 2025, 01:05:39 AM *
Author Topic: WIPER RETURN  (Read 4242 times)
yackboy49
EARLY HOLDEN CAR CLUB INC. WANGARATTA
« on: March 10, 2017, 07:21:15 PM »
Hi all,
wiper arm is not returning to bottom of screen, the left one does, however the right one stops in the middle of vision.
Is the drive worn, and how do you repair it, is accessibility under the dash, or via the top outside ?
Phil
« Reply #1 on: March 11, 2017, 05:05:27 AM »
It could be as simple as the wiper arm being in the wrong position! Does the wiper go down to the bottom of the screen when in use? It could be the connecting rod is worn, you need to look under the dash where the wiper motor comes through the firewall you will see the two rods going the the left and right. There is a nut and a clip holding the offset rods onto the motor.(be careful not to loose the clip)
« Reply #2 on: March 12, 2017, 02:45:08 PM »
The arms under the dash are the most likely cause.
First are the rubber bushes where the rods connect to the motor
Second are the linkages at the other end of the arm which get very worn and sloppy.
yackboy49
« Reply #3 on: March 25, 2017, 10:35:59 AM »
Thanks for the replies. Where do you get the bushes and a new arm ?
regards
Phil.
Phil
« Reply #4 on: March 25, 2017, 06:34:55 PM »
I believe Rares have new bushes, good second hand arms should be around.
Page created in 0.021 seconds with 19 queries.
