July 09, 2024, 05:36:05 AM *
Author Topic: exterior top front door trims  (Read 2790 times)
GMHwagoon
« on: January 14, 2016, 05:42:10 PM »
   help needed
                       was going through my collection of stainless  trims  polishing them up
                       ready for my fc wagon resto
                       found that a couple of the trims that run across the top of the front doors
                       have a slightly different curve at the ends   would these be fe door trims not fc ?
                         thanks greg
« Reply #1 on: January 14, 2016, 07:56:19 PM »
Not aware of any difference between FE and FC and the part numbers are the same.
Can you post a photo?
Maybe they have been bent.
Stewy
sa-club
Jeff Stewart
« Reply #2 on: January 14, 2016, 08:32:18 PM »
I did not think there was any difference, but the part # is not the same.
12.112 moulding assembly-- front door
Belt .........  FE/225, FE/229 .............LH 7410235
                                                      RH 7410236
Belt .........  FC/225, FC/229 .............LH 7411361
                                                       RH 7411362
And the lower belt
Belt .......... FE/225, FE/229, FC/225, FC/229 ........... 7410052   by 2
I only added this one to be sure that I wasn't getting the upper and lower mixed up?
I also can't find a record of the part # being changed in the master parts catalogue.
Cheers Stewy   Cool
« Reply #3 on: January 14, 2016, 09:44:30 PM »
Oops rereading the original post, now I see you meant external chrome stripes. When I read "trim" I thought door trim. My bad  Tongue
Good to see you're on the ball Stewy Grin
Now I have to completely change what I said. Stewy's part number search is right on the money.
FE stripe sits higher on the door so has a very small curve at the front.
FC stripe sits lower so has a large curve at the front.
Sorry about my stuff up Undecided
Page created in 0.045 seconds with 19 queries.
