August 20, 2025, 11:23:00 PM *
Author Topic: oil in radiator  (Read 3168 times)
moetstockie
« on: December 01, 2015, 08:59:39 PM »
Folks
        I have a little oil in radiator water but no water in my oil. 138 grey motor FE wagon. Ideas on what the problem could be?  Moe`t
« Reply #1 on: December 02, 2015, 12:03:22 PM »
Water in the oil is sometimes not as bad if we are talking side plates as it can be something as simple as a welsh plug under the side cover. But oil in the water only , that would infer its coming in under pressure . Like a blown head gasket , cracked or corroded head . Have you checked the spark plugs for signs of water or after it cools after a long run does it run rough on start up? Anyway you look at it ,not good news .Haydn
JOX515
« Reply #2 on: December 02, 2015, 01:15:12 PM »
On the bright side tho Moe`t, at least your radiator shouldn't rust Smiley
moetstockie
« Reply #3 on: December 06, 2015, 12:21:40 PM »
Thanks HSV - 001,  Sounds like there is a bit of a consensus on this. Will look at head gasket or a crack in head ......  Sounds like we need to do a little work on the rocket.  Thanks Moe`t
Page created in 0.023 seconds with 19 queries.
