August 10, 2025, 02:32:05 PM *
Author Topic: Grey gear box - reverse gear goes forward  (Read 3579 times)
Trevor_B
Melbourne VIC
« on: June 05, 2015, 12:29:10 PM »
Hi guys,
Rebuilt a grey gearbox recently and when installed reverse gear moves the car forward  Huh
All other gears work correctly.
My guess is that I installed the reverse idler gear backwards (despite Harv's warning in his rebuild guide  Embarrassed ) although I don't know if that is possible.
Any advice/similar experiences appreciated prior to pulling box out.
Trevor_B
Trevor_B
Melbourne VIC
« Reply #1 on: June 05, 2015, 10:39:28 PM »
Found the issue.... it was a selector rod adjustment issue as other gears also selecting incorrectly or not at all.
Someone else had installed dodgy selector rods.
Trevor_B
« Reply #2 on: June 06, 2015, 06:42:19 AM »
Glad to hear you found the problem Trev.
The reverse idler will only go in one way - the helical cut of the gears makes it clash if you try to go the other way around.
Page created in 0.025 seconds with 19 queries.
