April 26, 2024, 08:23:55 AM *
Pages: 1 2 3 [4]   Go Down
Author Topic: Grey motor bits and pieces -Ebay Gumtree Finds  (Read 88554 times)
TassEK
« Reply #60 on: December 18, 2016, 08:14:45 PM »
Seller says "scrap only"  motors and parts so guessing they are rough but there is a heater sender which might be worth the price - it is at South West VIC
 http://www.ebay.com.au/itm/HOLDEN-GREY-SINGLE-TEMP-SENDER-HEADS-48-FJ-FE-FC-X2-MOTORS-PARTS-ONLY-SCRAP-/252686410287?hash=item3ad548a22f:g:0rQAAOSw6wRXAOzK
Better prospect at Sydney or have I posted this one before
http://www.ebay.com.au/itm/EARLY-HOLDEN-GREY-MOTOR-AND-GEARBOX-/291974608291?hash=item43fb0af5a3:g:ZVsAAOSw4GVYHxRp
« Reply #61 on: December 18, 2016, 09:57:05 PM »
Notice the first one has basically fallen / rusted through the bottom of the front suspension into the ground, even the remains of the K frames are still there where they have rusted off the bottom of the car. Even the steering column has basically rusted away. How bad must the rest of the car been?
The second one looks like the car was rolled over and the engine was unbolted and dropped onto the ground. Rocker cover is punched in, carb is broken, oil filter is broken (shame)
TassEK
« Reply #62 on: December 23, 2016, 05:31:26 PM »
Here is a grey motor painted red at Gaythorne  Qld,  I think that is out Everton Park way isn't it.
http://www.ebay.com.au/itm/Holden-grey-motor-/162326018322?hash=item25cb627912:g:gZ4AAOSwZQRYVzlI
Head with a heater tap attached at Nhill (is that North Hill maybe not ) VIC Seller is more concerned about postage arrangements than a description
http://www.ebay.com.au/itm/HOLDEN-Grey-motor-cylinder-head-from-EK-or-FB/371771878451?_trksid=p2047675.c100010.m2109&_trkparms=aid%3D777003%26algo%3DDISCL.MBE%26ao%3D1%26asc%3D39923%26meid%3D459fffbb6e574e5793149e8f9e947689%26pid%3D100010%26rk%3D5%26rkt%3D6%26sd%3D162326018322
Same seller has a crank with clutch attached
http://www.ebay.com.au/itm/HOLDEN-Grey-motor-crankshaft-from-EK-or-FB/222292377870?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D2%26asc%3D39923%26meid%3D8064f94f93954026b5ea93855a544dc3%26pid%3D100005%26rk%3D1%26rkt%3D5%26sd%3D371771878451
TassEK
« Reply #63 on: April 10, 2017, 09:01:59 PM »
Motor and box
https://www.gumtree.com.au/s-ad/springton/engine-engine-parts-transmission/holden-grey-motor/1144579119
Seller's description
This is an original grey motor and gearbox from fe holden wagon however will suit fx, fj, fc, fb, ek or ej. In unknown condition as per photos however turns over by hand quite freely with ease.
TassEK
« Reply #64 on: April 11, 2017, 07:26:32 PM »
Motor in a Forklift - there was a lot of that going on back in the day
It is at  St Clair west of Sydney  https://www.gumtree.com.au/s-ad/st-clair/engine-engine-parts-transmission/holden-ek-grey-motor-/1144683207
and the seller says
"Holden 138 grey motor,complete see running as still fitted in vintage forklift ,lifting equipment here to aid removal and loading". Can't say fairer than that.
Here  is a motor and box with a front end chucked in - it is at Botany NSW
https://www.gumtree.com.au/s-ad/botany/other-parts-accessories/holden-grey-motor-front-suspension-complete-fc/1141960899
Seller says :Holden Grey motor front suspension and driff all complete from running FC
$300.
For inspection or pick up located in Botany NSW 2019.
Only serious buyers to inquiry.
TassEK
« Reply #65 on: May 07, 2017, 09:55:54 PM »
There is a EJ Grey that was once fitted to a Land Rover at Ballina (A Land Rover - seriously) @ $800 probably needs to be in good condition
https://www.gumtree.com.au/s-ad/ballina/engine-engine-parts-transmission/holden-long-grey-motor/1147036634
There is an FC motor in western Australia (Yorkine WA actually) but you will have to take an industrial vacuum cleaner to remove the dust
https://www.gumtree.com.au/s-ad/yokine/engine-engine-parts-transmission/holden-grey-motor/1146299559
A cheaper motor here in the west also- Kenwick WA
https://www.gumtree.com.au/s-ad/kenwick/engine-engine-parts-transmission/holden-fe-grey-motor/1145314453
Cheap head at Boronia Heights South of Brissy
https://www.gumtree.com.au/s-ad/boronia-heights/engine-engine-parts-transmission/holden-grey-motor-head-vgc/1146084373
There is a Marinised motor at Adelaide
https://www.gumtree.com.au/s-ad/valley-view/engine-engine-parts-transmission/marinised-grey-motor/1145731879
Motor at St Clair (West of Sydney)
Head at Victor Harbor
https://www.gumtree.com.au/s-ad/victor-harbor/engine-engine-parts-transmission/holden-grey-motor-cylinder-head-fb-fc-ej/1141375333
« Last Edit: May 07, 2017, 10:04:25 PM by TassEK » Logged
TassEK
« Reply #66 on: June 22, 2017, 08:58:50 PM »
Motor at Brisbane - turns over - at Banyo Brissy
http://www.ebay.com.au/itm/Holden-Grey-Motor-FX-FJ-FE-FC-FB-EK-EJ-/222553617218?hash=item33d13ab342:g:QNQAAOSwTf9ZSj4N
Thirmere NSW there is a motor
http://www.ebay.com.au/itm/Holden-grey-motor-engine-to-suit-48-215-FX-FJ-fc-fe-fb-ek-ej-/292155447052?hash=item4405d2570c:g:lZgAAOSwsXFZMMfW
Here is a rusty number at Melton South Vic
http://www.ebay.com.au/itm/Holden-grey-motor-138-FB-engine-FC-EK-FE-FX-FJ-EJ-48215/252958929259?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D20140106155344%26meid%3Dedf7028813224b588a38c213cc0e9022%26pid%3D100005%26rk%3D1%26rkt%3D5%26sd%3D292155447052&autorefresh=true
Block at Park Ridge Brissy
http://www.ebay.com.au/itm/vintage-holden-grey-engine-block-fj-fe-fc-fb-nasco/142419267428?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D20140106155344%26meid%3Dedf7028813224b588a38c213cc0e9022%26pid%3D100005%26rk%3D3%26rkt%3D5%26sd%3D292155447052
Motor at victoria ??
http://www.ebay.com.au/itm/holden-grey-motor-fe-fc-fb-ek-ej-engine-number-b188743-nasco-/232355122283?hash=item361971cc6b:g:aXAAAOSw4CFYoER-
Couple of blocks $100 each
https://www.gumtree.com.au/s-ad/ormeau/engine-engine-parts-transmission/holden-fj-grey-motor-blocks-132-138/1151665095
Top dollar for a recon head
https://www.gumtree.com.au/s-ad/tweed-heads-south/engine-engine-parts-transmission/holden-cylinder-head-suit-132-138-grey-motor/1151508662
Motor with marinated - sorry marinised sump
https://www.gumtree.com.au/s-ad/morisset-park/engine-engine-parts-transmission/holden-grey-motor-with-marinised-sump/1149187114
Motor at Penrith - in a forklift
Full motor< I think, which has been marinised at Warragul
TassEK
« Reply #67 on: June 29, 2017, 09:29:01 PM »
Motor and box way out west from an FB apparently
https://www.gumtree.com.au/s-ad/kelmscott/engine-engine-parts-transmission/holden-grey-motor-and-gearbox-fx-fj-fe-fc-fb-ek-ej/1152452255
An EJ motor and Hydro-box could be on the expensive side at Maitland NSW
http://www.ebay.com.au/itm/Grey-motor-138-and-Hydromatic-gearbox-from-EJ-Holden-may-suit-FE-FC-FB-EK-/182642661147?hash=item2a8659d71b:g:S-4AAOSwPWRZVILJ
TassEK
« Reply #68 on: July 11, 2017, 07:10:40 PM »
Grey Motor from an FJ but hey it is grey not red or blue.  Comes with lots of odds and sods. Oh and it is at Belrose NSW
http://www.ebay.com.au/itm/Holden-FJ-Grey-Motor-Plus-/132256066194?hash=item1ecb136a92:g:LlwAAOSwEUVZZHAL
Are you into looking for Bling - I have found it apparently it is at Epping VIC
http://www.ebay.com.au/itm/holden-grey-motor-totally-rebuilt-with-all-the-bling-nasco-gmh-/192241722864?hash=item2cc27fe5f0:g:RWYAAOSwEPtZYG9V
This one could be the same as the one in the last post on Gummie -Kingsley, WA
http://www.ebay.com.au/itm/138-holden-grey-motor-/282562636397?hash=item41ca0baa6d:g:s2kAAOSwKoRZYKJi
TassEK
« Reply #69 on: July 17, 2017, 08:23:34 PM »
Marinised motor at Morrisset NSW
http://www.ebay.com.au/itm/Holden-Grey-motor-with-marinised-sump-Bargain-/302384972108?hash=item46678c814c:g:zLMAAOSwPw1ZauNh
Motor in a forklift at Hobart
https://www.gumtree.com.au/s-ad/hobart-cbd/engine-engine-parts-transmission/-500-holden-138-grey-motor/1154195719
Two motors at Camira Brisvas -  oh look triple carbie setup on one
https://www.gumtree.com.au/s-ad/camira/engine-engine-parts-transmission/holden-grey-motors/1152226090
Marinised motor at Warragul
https://www.gumtree.com.au/s-ad/warragul/engine-engine-parts-transmission/holden-grey-motor-complete-marinised-for-boat/1143447547
TassEK
« Reply #70 on: September 12, 2017, 09:00:10 PM »
Rusty rebuild motor at Melton South Vic
http://www.ebay.com.au/itm/Holden-grey-motor-138-FB-engine-FC-EK-FE-FX-FJ-EJ-48215-/263164714467?hash=item3d45d6dde3:g:PQIAAOSww9xZKAgn
Motor at Morisset NSW
Motor and a gearbox at Sylvania NSW
http://www.ebay.com.au/itm/Holden-grey-motor-and-3-speed-gearbox-/122696907991?hash=item1c914e3cd7:g:VxwAAOSwPCFZtMLD
Motor at Port Fairy  Victoria
HOLDEN GREY MOTOR. COMPLETE. ENGINE NUMBER B188743.
STILL TURNS OVER
Located port fairy vic.
Freight at buyers expense.  Can deliver free to hoppers crossing if paid first
http://www.ebay.com.au/itm/holden-grey-motor-fe-fc-fb-ek-ej-engine-number-b188743-nasco-/232460173013?hash=item361fb4bed5:g:aXAAAOSw4CFYoER-
Motor with its own welder attached at Townsville
https://www.gumtree.com.au/s-ad/railway-estate/engine-engine-parts-transmission/holden-138-grey-motor/1158608205
TassEK
« Reply #71 on: October 24, 2017, 09:48:40 PM »
Time for an up date
Motor and gearbox at Bega NSW - https://www.ebay.com.au/itm/holden-grey-motor-/232534975918?hash=item36242a25ae:g:IXsAAOSwKQ9Z7qdf
Rust Motor and box at Melton South VIC
https://www.ebay.com.au/itm/Holden-grey-motor-138-FB-engine-FC-EK-FE-FX-FJ-EJ-48215-/263272028158?hash=item3d4c3c57fe:g:PQIAAOSww9xZKAgn
Expensive motor at Townsville ( I think for a motor in unknown condition I think $1K is a little steep - you can disagree)  - https://www.ebay.com.au/itm/FB-EK-Holden-Grey-Motor-and-Gearbox-/182831794409?hash=item2a919fc8e9:g:aV0AAOSwafBZ4set
I think this is a re-post but a motor and box somewhere in Victoria- https://www.ebay.com.au/itm/holden-grey-motor-fe-fc-fb-ek-ej-engine-number-b188743-nasco-/232514482992?hash=item3622f17330:g:aXAAAOSw4CFYoER-
Take your pick at Kalamunda motors and gearboxes - grey's and red's https://www.gumtree.com.au/s-ad/kalamunda/engine-engine-parts-transmission/138-grey-motors/1161861947  (Kalamunda is in WA - just saying)
There are some rusty motors down here in Tassie - 6 of them are  at Nunamara (North East of Launceston). Rusty and dusty but could find a winner. ($500 the lot- hell even if you only can make one good motor could be worth a look - https://www.gumtree.com.au/s-ad/nunamara/engine-engine-parts-transmission/6-x-grey-motors-suit-rebuild-500/1160819342
Motor at  - Morisset park (Between Gosford and Newcastle) https://www.gumtree.com.au/s-ad/morisset-park/engine-engine-parts-transmission/holden-grey-motor-with-marinised-sump/1149187114
Couple of items from the same seller at Tivoli Ipswich - Block  -https://www.gumtree.com.au/s-ad/ipswich/engine-engine-parts-transmission/holden-grey-motor/1162916996
and 4 heads - Look clean and at $100 each could help someone  https://www.gumtree.com.au/s-ad/ipswich/engine-engine-parts-transmission/holden-grey-motor-heads/1162917365
a Head for $150- can't see any cracks but then again you can't always tell - https://www.gumtree.com.au/s-ad/nambour/engine-engine-parts-transmission/holden-grey-motor-cylinder-head-/1163310947
Motor and spare block at western Sydney - https://www.gumtree.com.au/s-ad/edensor-park/engine-engine-parts-transmission/holden-grey-motors-fx-fj-fe-fc-fb-ek-ej/1162191602
Motor and two gearboxes at Rosewood west of Brisbane- https://www.gumtree.com.au/s-ad/rosewood/engine-engine-parts-transmission/fc-holden-grey-motor-with-2-gearboxes-/1162083087
« Last Edit: October 24, 2017, 09:56:16 PM by TassEK » Logged
TassEK
« Reply #72 on: October 25, 2017, 09:10:55 PM »
Block for sale at Gympie - https://www.ebay.com.au/itm/holden-grey-motor-1962-block/132374801024?hash=item1ed2272a80:g:G1cAAOSws~pZ3Z5U
Longman
« Reply #73 on: November 26, 2017, 07:58:41 AM »
Must be a Canadian block at this price!  Cheesy
https://www.ebay.com.au/itm/Holden-132-5-cu-inch-2-2L-Engine-Grey-Motor-for-FX-FJ-FE-FC-May-suit-138-2-3L/222732094321?hash=item33dbde0b71:g:~-YAAOSwZW5aGMVn
TassEK
« Reply #74 on: November 27, 2017, 09:40:33 PM »
This motor has been sitting in a shed for yonks (30 years) - it is $150 right now - catch is it is pick up only at Melton South VIC
https://www.ebay.com.au/itm/Holden-grey-motor-138-FB-engine-FC-EK-FE-FX-FJ-EJ-48215/253266875516?hash=item3af7e1d47c:g:PQIAAOSww9xZKAgn
There is an EJ motor on the Sunshine Coast
https://www.ebay.com.au/itm/HOLDEN-GREY-MOTOR-AND-GEARBOX/182867236518?_trkparms=aid%3D777003%26algo%3DDISCL.MBE%26ao%3D1%26asc%3D20140117125611%26meid%3Dc89dc683efe24c8ab91d37910b3865dc%26pid%3D100009%26rk%3D1%26rkt%3D10%26sd%3D253266875516&_trksid=p2047675.c100009.m1982
Holden 138 Grey motor, doesn't work needs a rebuild, attached is a 3 speed Gearbox... seems to be in working condition, Gearbox is still attached, both original from original 1963 EJ Holden , Cash only on pick up only from the  Sunshine Coast QLD
On the expensive side - perhaps Huh  I just paid $2k to have my motor rebored etc - but for an unknown motor does seem steep
https://www.ebay.com.au/itm/FB-EK-Holden-Grey-Motor-and-Gearbox/182908314595?hash=item2a962f63e3:g:aV0AAOSwafBZ4set
Is out of an FB Holden and was running when parked.
Turned over with a key.
Still had oil and water in it.
No Spark, points or coil....
It has 55,000 on Speedo.
Motor just says Victoria - I think this poster is selling a number of parts on Ebay and Gumtree
https://www.ebay.com.au/itm/holden-grey-motor-fe-fc-fb-ek-ej-engine-number-b188743-nasco/232551575490?hash=item3625276fc2:g:aXAAAOSw4CFYoER-
TassEK
« Reply #75 on: April 08, 2018, 08:47:02 PM »
Time for an update:
Holden Grey Motor with Alloy Rocker Cover and extractors at Upper Coomera
https://www.ebay.com.au/itm/Holden-Grey-Motor-with-Alloy-Rocker-Cover-and-extractors/183159478266?hash=item2aa527d7fa:g:iCsAAOSwRk9aqDHb
Seller says:
Holden Grey Motor
Originally out of our FB
good strong motor was running well when removed
Grab this at a good price, I've seen non-working ones at a higher price than this.
Check out my other stuff, I am clearing out 25 years of collected car bits.
Cash on pick up preferred
Motor and box on the Sunshine coast
https://www.ebay.com.au/itm/HOLDEN-GREY-MOTOR-AND-GEARBOX/182867236518?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D20140106155344%26meid%3D5d28f343043148c5839a78c61a54400d%26pid%3D100005%26rk%3D2%26rkt%3D6%26sd%3D183159478266%26itm%3D182867236518&_trksid=p2047675.c100005.m1851
This one was first posted in November and I assume still for sale - Just says Victoria.
Motor only at Greenbank  Brissy way
https://www.gumtree.com.au/s-ad/greenbank/engine-engine-parts-transmission/holden-grey-motor/1179006574
There is an EJ motor at Eastern Height Queensland- Nothing wrong with an EJ that what my ute will have.
https://www.gumtree.com.au/s-ad/eastern-heights/engine-engine-parts-transmission/holden-138-grey-motor/1178895725
Seller says:
This is a Holden 138 Grey Motor that came out for the EJ Holden.
The condition is unknown, however it is not seized and can turn over by hand.
It would be great for a restoration project.
At the other end we have an FJ FX motor out west - or s it as the seller does not know.
Out of my FX Holden is the grey motor we think its a 132 but could be 138. We do know it was a Repco exchange motor believed to be from a FC Holden. Doesn't turn over been the car since early 1960's sold in as is condition as pictured
https://www.gumtree.com.au/s-ad/malaga/engine-engine-parts-transmission/fx-fj-holden-engine/1178524738
Motor and gearbox at Altona VIC
https://www.gumtree.com.au/s-ad/altona/engine-engine-parts-transmission/holden-grey-motor/1178293019
Motor and gearbox on the Gold Coast
https://www.gumtree.com.au/s-ad/southport/engine-engine-parts-transmission/grey-motor-gearbox/1178258613
This motor is a little expensive but may be worth the money - it is at Mount Compass
https://www.gumtree.com.au/s-ad/mount-compass/engine-engine-parts-transmission/holden-grey-motor-good-condition-low-hours-can-be-heard-runing-/1176065229
Here is an old roughie at Tamworth.
https://www.gumtree.com.au/s-ad/oxley-vale/engine-engine-parts-transmission/holden-grey-motor-138-has-gearbox-would-need-full-rebuild-/1168286122
Pages: 1 2 3 [4]   Go Up
Page created in 0.044 seconds with 20 queries.
