August 13, 2025, 01:17:53 PM *
Author Topic: Inner door rubbers  (Read 5597 times)
DJ
« on: December 04, 2014, 10:39:02 AM »
After reading through the various posts on which way the inner door seals sit, I'm still not 100% certain.
Would anyone have a diagram or even a crude drawing showing the section sitting inside the channel?
0417 270 315
« Reply #1 on: December 04, 2014, 10:51:59 AM »
Half way down the page
How to - Changing Door Seals
Re:
« Reply #2 on: December 04, 2014, 11:21:13 AM »
DJ if you still have trouble, I am sure if you wander into a local panel beater that they will demonstrate it to you. The other issue could well be that you aren't holding your mouth right.
DJ
« Reply #3 on: December 04, 2014, 01:06:33 PM »
Thanks Pete, some good tips in that lot.
The outer wasn't much trouble & I'm at the stage of doing the mitres, so it was good to see the vid & pics.
The inner seal I have is bagged in a 'Bill Thompson' package. I think now that it's a slightly different profile compared the pictures I've looked at, hence the hesitation.
Quite right ..... combined with failing eyesight & a tolerance level lower than it used to be.
0417 270 315
JOX515
« Reply #4 on: December 04, 2014, 04:34:58 PM »
Just take your time DJ - I took it very slowly when installing my door rubbers and all worked well.
Patience is a virtue when doing the rubbers......
Cheers, Graeme
DJ
« Reply #5 on: December 04, 2014, 07:12:55 PM »
I hear those word in the background ..... it may not happen overnight .....
0417 270 315
« Reply #6 on: December 04, 2014, 07:25:58 PM »
Finding a nice workable glue is the main hurdle contact adhesive is painful gets everywhere messes up the paint if spilt .
What glue are people using ?
Loctite 403, 406 is great for quick fixes but ive found water can loosen it and its really runny.
I have used ZAP thick its for model aeroplane buildiing its ok too but im not sure what to use on the ute..
Pete
DJ
« Reply #7 on: December 04, 2014, 07:51:20 PM »
Advice from a panel beater/spray painter was that the Loctite can pull the paint away & tear the rubber if you try to move it around once it's set.
The contact can be messy so he prefers to use the small tubes with nozzles & doing only a couple of feet at a time. The biggest advantage of using contact was that Prepsol will soften it without damaging the paint, allowing easy clean up & removal of the rubber if you need to.
0417 270 315
« Reply #8 on: December 04, 2014, 08:19:45 PM »
Thanks for the info ill be extra careful..
DJ
« Reply #9 on: December 04, 2014, 09:00:25 PM »
I found cutting for the 90 degree corners a little difficult using scissors. The photo using the knife & board looks like the go.
Can't see you having much trouble with your trained eye.
0417 270 315
« Reply #10 on: December 04, 2014, 09:05:23 PM »
I fit foam tape gaskets to gland plates at work.
Ive found the autosmart razor blades work well sharp and pretty large so you can get a square cut.
DJ
« Reply #11 on: December 04, 2014, 09:12:30 PM »
Very good, thanks. I have a go with them. Sharper would be better so the material doesn't move around.
0417 270 315
Page created in 0.026 seconds with 20 queries.
