May 18, 2025, 04:26:44 AM *
Author Topic: FE Brake Booster options  (Read 2442 times)
FC-V8
Not enough hours in the day
« on: October 16, 2000, 01:00:00 PM »
Is there a known "easy fit" firewall mounted brake booster for the FE/c Holden. I have started work on fitting a LC/J Torana booster to the firewall and I can see a couple of problems, has anyone done a conversion like this? Any advice before I start drilling and cutting the firewall. Thanks.
0401-065-201
FEV008
« Reply #1 on: October 17, 2000, 01:00:00 PM »
Hey Glenn,
I put a HK twin circuit booster in my FE.  fits like it was facotry!, all you have to do is cut and reweld the brace that attaches to the engine bay walwall, and from memory drill a hole here and there.  i think the pushrod was adapted from HK end and stocky pushrod.. its pretty easy good luck..  Ive seen the LJ booster before and it had a sort of cam on it that allowed the pushrod to push properly.. looked ghastly but was effective.  100 points for the guy that had the patience.
FEV008
« Reply #2 on: October 17, 2000, 01:00:00 PM »
Hey Glenn,
FC-V8
« Reply #3 on: October 17, 2000, 01:00:00 PM »
I take it you mean that the LJ setup used the original bracket and linkages for the firewall? I am attaching the booster direct to the firewall with the pedal/pushrod connecting direct to the booster. If I am not mistaken the HK booster should be very similar if not the same as an LC/J booster. Looks like I am on the right track anyway. Thanks.
0401-065-201
chris stokes
« Reply #4 on: October 02, 2001, 01:44:06 PM »
I fitted a vacuum booster to my 58 FC sedan, however , I retained the original master cylinder. The booster is a PBR 40 something and is mounted down in the lower right hand inner guard. It was a VERY simple install with no cutting or welding to satisfy the originality freaks, easy access for maintenance and is easy on the eye. It operates simply as a slave to the master cylider. Probably the only tricky bit is making up the two flared lines , otherwise ring enzed~!~~
