August 11, 2025, 11:15:15 PM *
Author Topic: Roof lining  (Read 3464 times)
mickrat
« on: October 16, 2014, 07:52:26 PM »
I am in the process of fitting my new rooflining have the wire stays in place ,front and rear fixed with large paper clips what should I be using for the glue  mickrat. [/IMG]
« Reply #1 on: October 16, 2014, 08:34:58 PM »
Contact adhesive, try Bunnings or other hardware stores.
fe1957
Turbo Charged
« Reply #2 on: October 19, 2014, 08:12:41 PM »
Stinky made my rooflining looks fantastic,  a good trick for holding the glued lining is bits of pinchweld instead of paper clips
Grant
OFE570
mickrat
« Reply #3 on: October 19, 2014, 11:47:15 PM »
Roof lining is in and glued have a few wrinkles no matter which way I pull it don't seem to be able to get them all out will a bit of heat from a heat gun down low. Stretch and shrink it for a smoother finish or am I stuck with what I have Huh  Mickrat
Re:
« Reply #4 on: October 21, 2014, 10:03:07 AM »
Mickrat, if you look at some YouTube videos it might give you a few different methods.
« Reply #5 on: October 23, 2014, 01:43:22 PM »
To pull out a crease you to tighten/pull perpendicular to the crease (across the crease).
If you want to use heat get a hair-dryer as a heat gun can heat it too quickly and you will ruin the job completely. When heating, always keep touching the heated area to test it, if it is too hot to touch STOP!
Page created in 0.027 seconds with 21 queries.
