August 11, 2025, 05:27:55 AM *
Pages: 1 [2]   Go Down
Author Topic: Where do these bits go  (Read 19465 times)
collecta
« Reply #20 on: August 23, 2014, 07:16:02 PM »
Cowl vent has phillips head fine thread screw/bolt with nut and washer.
Scott
Stewy
sa-club
Jeff Stewart
« Reply #21 on: August 23, 2014, 08:49:41 PM »
like this
Cheers Stewy
Professor Grey
« Reply #22 on: August 24, 2014, 09:50:55 AM »
G'day Keith,
The measurements you have given us don't tally up even remotely with the picture. (not having a go at you  Cheesy)
Get your vernier out and have another go.
Gaz
KFH
« Reply #23 on: August 24, 2014, 04:08:37 PM »
Hi Gaz.  I used a ruler and my calibrated eye to make the measurements.  Maybe the angle At which I took the photo may cause some distortion to apparent measurements.  I am away from home at the moment and will use the vernier when I get back home in the middle of the week.  So far no answers seem to fit the bill.  It is annoying when you have these bits left and did not find a spot for them during assembly.  Definitely not a radio as in my 50 + years of working with them I have never seen a mechanical part like this.
« Reply #24 on: August 25, 2014, 07:39:39 AM »
That's called a PARALLAX effect.
Parallax is a displacement or difference in the apparent position of an object viewed along two different lines of sight, and is measured by the angle or semi-angle of inclination between those two lines.
Old_Mt_Isa_Boy
My Ute
« Reply #25 on: August 25, 2014, 09:19:35 AM »
That's why your a guru  Grin
Wayne b
Sheriff
FEs rule!
« Reply #26 on: August 25, 2014, 07:22:10 PM »
rear exhaust hanger bolt....in spare wheel well?Huh
FE_280E
« Reply #27 on: August 26, 2014, 01:16:05 AM »
I'm with Sheriff. Yeah, bolt in the spare wheel well for the exhaust hanger with the stock tail pipe, but there is only one there. Been soo long since I broke down mine...
« Last Edit: August 26, 2014, 01:22:23 AM by FE_280E » Logged
collecta
« Reply #28 on: August 26, 2014, 01:18:32 PM »
Most bolts that are being mentioned eg; ute tailgate bump stop, exhaust hangers have a square head like the bumper bolts not slotted like the ones pictured.
Scott
KFH
« Reply #29 on: September 01, 2014, 10:11:53 PM »
OK to make sure I didn't give the wrong measurements  here are what my digital vernier gives me.  I'll give them in imperial and metric.
Overall length -----------------    .60" - 15mm
Head diameter -----------------   .49"  - 12.4mm
Head thickness -----------------  .06"  - 1.6mm   The head is domed
Shank length from under head --- .19"  -  4.8mm
Diameter of shank---------------- .227"  - 5.7mm
Across the flats on shank -------- .170"  - 4.27mm
Length of thread -----------------.35"  - 8.4mm
Diameter of thread --------------  .147"  - 3.57mm
So far the answers do not seem to be correct.  As I previously said this is not a trick question.
FC Holden 2104
sa-club
« Reply #30 on: September 02, 2014, 05:36:12 PM »
Rear Bumperette bump stop bolts ??
South Australia
Re:
« Reply #31 on: November 12, 2014, 11:22:41 AM »
I think its something inside the door or qtr window etc but not a genuine one. But it doesn't look very used in the pick where it locates.
Re:
« Reply #32 on: November 12, 2014, 12:52:12 PM »
Did u take apart electricals? Maybe a terminal bolt.
Pages: 1 [2]   Go Up
