July 19, 2025, 10:33:23 AM *
Author Topic: Harmonic balancer pulley - red or Starfire  (Read 1110 times)
« on: May 10, 2014, 07:02:47 AM »
Getting closer and closer to having the first Norman supercharger running on a grey. The next step in the process is to sort out the drive system.
I'm looking for a harmonic balancer pulley please. Not the harmonic balancer itself, but the (relatively flat) pulley that bolts to the front of it. The pulleys I have in minds are those from either red motors or Starfire 4's, which have three bolt holes along with the central bore hole. I need preferably double pulleys (to run two belts) but also happy to look at triples (three belts). Pulleys will need to be relativedly flat as clearance to the radiator is not huge. I'm going to need a few of these, so if you have more than one I'm happy to take a couple. Diameter is not a huge drama at this stage as I can tune the supercharger pulley to suit.
Let me know how much cash you are after, including postage to Sydney.
Harv (deputy apprentice Norman supercharger fiddler).
