September 28, 2024, 10:16:21 PM *
Author Topic: Challenge no 4  (Read 5611 times)
« on: January 27, 2014, 01:29:32 PM »
Here's a new one to try and stump you
Whilst not strictly in the parts book, it came into use on FE and FC vehicles
DJ
« Reply #1 on: January 27, 2014, 02:50:09 PM »
Is it an insert for the inside door lock knob.
0417 270 315
« Reply #2 on: January 27, 2014, 03:05:39 PM »
Tube insert .....FC427......
surferboy
10,000 POINTS !
« Reply #3 on: January 27, 2014, 05:04:29 PM »
I must be looking at the wrong pictures  Huh
Looks like two pics of the head of a black square Phillips head screw  Huh Huh Huh
 Cool Cool Cool
cruisin's great with a 58
« Reply #4 on: January 27, 2014, 05:43:27 PM »
I don't know why pics have disappeared.
Try again
« Reply #5 on: January 27, 2014, 05:47:12 PM »
And this one
Maco
« Reply #6 on: January 27, 2014, 07:43:26 PM »
Is it a Valve Stem seal.
Better in Green
« Reply #7 on: January 27, 2014, 08:04:51 PM »
You're on the right track, tell me why these are used and not on FB or EK for instance Roll Eyes
« Reply #8 on: January 27, 2014, 08:33:43 PM »
The early rims had a larger hole
john253a
« Reply #9 on: January 27, 2014, 08:39:23 PM »
because there on a bench top and not in the car? Tongue
Good + Fast = Not Cheap
Cheap + Fast = Not Good
Good + Cheap = Not Fast
« Reply #10 on: January 28, 2014, 02:06:10 AM »
FE & early FC had the larger valve stem hole in the wheels for tubeless tyres which I believe were
fitted from new
The early tubeless valve stems were wider at the base than the ones we use today
When fitting tubes these doo hickey's were required to centre the valve stem within the larger hole
As the early wheel centres were only riveted to the rims, tubeless tyres were sometimes prone to leaking air
from the rivet holes
Later on the rivets were replaced with spot welds
Up until a few years ago you could still hunt down the wider tubeless valve stems, not sure if they are still available these days
gp
« Reply #11 on: January 28, 2014, 03:14:35 PM »
From memory I'm sure I've seen a bulletin stating that Holden went to tubeless tyres sometime in 1955, during FJ production???
Dr_Terry
« Reply #12 on: January 28, 2014, 03:35:11 PM »
Hi gp.
My service bulletins state Jan 1956 for tubeless tyre intro.
Dr Terry
« Reply #13 on: January 28, 2014, 05:56:22 PM »
Zulu, I couldn't have said it better. I'm pretty sure the larger tubeless stems are still available. I had them fitted on the 3 tone sedan but that was a little while ago I guess. Cry
Stewy
sa-club
Jeff Stewart
« Reply #14 on: January 28, 2014, 06:20:53 PM »
Picked up a couple from bob janes 2weeks ago  Smiley
Cheers Stewy   Cool
