August 19, 2025, 02:33:11 AM *
Pages: 1 [2]   Go Down
Author Topic: Tailshaft U Bolts  (Read 13128 times)
« Reply #20 on: January 03, 2014, 08:58:11 PM »
where you located ?
put a 3.36 in it with normal unis in my opinion better set up with todays smaller tyre heights.
« Reply #21 on: January 04, 2014, 06:25:22 AM »
I think the penny has dropped, check the box and each cup, if each cup has a groove around the inside edge closest to the joint and there are 4 circlips in the box then you a front uni joint as it needs a clip on each cup to hold them in place.
muzzie
« Reply #22 on: January 04, 2014, 08:59:28 AM »
Located in gormandale Victoria, the uni has grooves in it the same as the front but only two are in it. Thanks muzzie
« Reply #23 on: January 04, 2014, 12:42:50 PM »
Muzzie, have a look at "A UNIVERSAL PROBLEM" I have posted in general technical, hope it helps you
« Reply #24 on: January 04, 2014, 01:00:55 PM »
I forgot to mention, have another look at your uni, if the dust covers are inside the cup it would be an early one, if so you are welcome to the flanges and bolts, bear in mind the needle rollers could be worn.
muzzie
« Reply #25 on: January 06, 2014, 03:37:34 PM »
yeah g'day Jim, read through "universal problems" thanks for taking the time out to help, i have worked out i need the flange and bolts to fit my tailshaft. Did you say you had some there? Thanks Muzzie
« Reply #26 on: January 06, 2014, 06:28:38 PM »
Muzzie, no problem, give me a call on 0419632935, if I don't answer leave a message and I'll call you back, or send me your details via message in the forum.
Pages: 1 [2]   Go Up
