May 22, 2025, 11:53:59 PM *
Author Topic: Door window rubbers?  (Read 9440 times)
jwm
« on: December 11, 2013, 09:09:21 PM »
I'm just wondering what people use, or what can be used, for the the internal window rubber that runs along the top of the door between the 2 rails that window runs up and down in.
Not sure I've explained that very well
« Reply #1 on: December 11, 2013, 09:13:55 PM »
Do you mean the felt with the chrome trim on it that rubs each side of the glass as it goes up and down?
jwm
« Reply #2 on: December 11, 2013, 09:20:01 PM »
That's it, I don't have any internal ones on my sedan and I was looking to replace them with something. I thought maybe a molded rubber product that could be glued in place as a replacement as I dont' have the mounting clips.
« Reply #3 on: December 11, 2013, 09:57:03 PM »
they are called bailey chanels and there are some listed on ebay in fc holden
jwm
« Reply #4 on: December 12, 2013, 02:04:56 PM »
Thank you, I'll have a look.
« Reply #5 on: December 12, 2013, 04:49:40 PM »
They are readily available as a repro. They come with the clips attached
jwm
« Reply #6 on: December 13, 2013, 02:59:19 PM »
Isn't the Bailey Chanel the actual chanel that the window runs up and down in? I'm actually after the rubber/felt strip that runs across the top of the door horizontally at the bse of the window frame/Bailey chanel?
« Reply #7 on: December 13, 2013, 03:18:33 PM »
Ok, they are the belt strips, should be available from Rare spares.
Townee
« Reply #8 on: December 13, 2013, 05:12:09 PM »
are these what you are looking for?
http://www.ebay.com.au/itm/HOLDEN-FE-C-FRONT-DOOR-BELT-KIT-/251349247049?pt=AU_Car_Parts_Accessories&hash=item3a85952449
Townee (NSW}
jwm
« Reply #9 on: December 14, 2013, 04:32:36 PM »
Thanks guys, that's them. I just need to get christmas out of the way and paid for and then I'll order a set.
« Reply #10 on: December 17, 2013, 04:33:26 PM »
Alternatively, I saw a restoration procedure for these either here or on the FB/EK forum. The article used grey stick-on draftstopper from the hardware, but I know you can buy black gear through "Fitch the Rubberman" in Adelaide by the metre and in various pile depths. You'd probably save yourself over $100 if you have the old ones still.
« Reply #11 on: December 17, 2013, 06:18:39 PM »
Poor mans door belts (and cool tech):
http://www.fbekholden.com/forum/viewtopic.php?f=5&t=16814
Crumpsnr
Shellharbour NSW
« Reply #12 on: December 17, 2013, 08:37:33 PM »
What a brilliant solution!  Smiley
« Reply #13 on: December 17, 2013, 10:39:23 PM »
Thanks Harv, that's the one. I used the same method to repair ones from a Cadillac.
Page created in 0.037 seconds with 21 queries.
