August 16, 2025, 11:35:14 PM *
Author Topic: front door adjustment  (Read 1545 times)
surferboy
10,000 POINTS !
« on: October 27, 2013, 01:55:56 PM »
Front passenger side door started dropping about an inch when opened and you needed to lift it to close.
Pulled the door panel off, jacked up the door with a couple of car jacks and went to tighten the 6 bolts holding door to hinges
Found some had nuts on them and some didn't.
Some of those that didn't have nuts were not tightening up
Workshop manual doesn't mention nuts. It just says the bolts screw into a floating plate
I'm guessing the threads have been worn and a longer bolt and nut has been fitted.
Do I need to do this with the remaining bolts ?
They are in a pig of a location to get a spanner in the space to hold the nut !
I've got the door closing better now but I think it will need a more permanent fix
Ta
 Cool Cool Cool
cruisin's great with a 58
« Reply #1 on: October 27, 2013, 07:02:38 PM »
Surferboy
If it was mine, I would get a tap (you need slightly larger than 5/16 unf)
and new bolts to match, then tap new threads in the hinge plate,
Gary
Page created in 0.019 seconds with 19 queries.
