August 23, 2025, 09:32:48 AM *
Author Topic: Early FE Hubs & Brakes Wanted Urgently  (Read 8888 times)
59Special
« on: October 05, 2013, 11:31:11 AM »
G'day Guys,
I am looking for a set of "early" FE hubs & brakes to fit to onto my FJ ute.
I have read that they will bolt straight up, i would imagine these would be sitting around in peoples sheds due to many fitting HR front ends.
I'm happy to pay accordingly + freight, so if you have a set i have the cash and can do direct deposit.
Cheers, Jack  Cool
1955 Holden FJ Ute
1959 Holden FC Special Sedan
1966 Holden HR Premier Sedan 350 Chev
2006 Nissan Elgrand Rider Autech
« Reply #1 on: October 05, 2013, 12:25:59 PM »
Yes they do bolt straight up, but they are not as common as you would think. These have been desirable since the sixties and even a lot of FE's now have the later hubs fitted because of the cost of the bearings and the fact that the later hubs and stub axles are very cheap.
59Special
« Reply #2 on: October 05, 2013, 02:10:09 PM »
Ken,
Thanks for the info, would you know if i could bolt the later FE/FC stub axles (hubs, brakes) straight up to the FJ crossmember?
Cheers, Jack  Cool
1955 Holden FJ Ute
« Reply #3 on: October 05, 2013, 02:15:47 PM »
No you can't - that's the point. The FJ stub axle is totally different to later models. It just so happens that early FE bearings are the same as FJ. Later FE bearings changed and stayed the same even into Commodore.
But FC, FB, EK, EJ and EH stub axles will fit into early FE making the FE easily upgradeable but not the FJ.
59Special
« Reply #4 on: October 05, 2013, 02:49:35 PM »
Ken,
Thanks very much for your help.
Cheers, Jack  Cool
1955 Holden FJ Ute
59Special
« Reply #5 on: October 05, 2013, 02:53:06 PM »
Ken,
I found this following post on the FJ forum.....
My old front end had been converted to 13in wheels
I believe its just a matter of taking out the upper and lower pins
removing the old stub axle and hub and putting the FC one in its place
I think the tie rods fit the new steering arms ok
I'm sure someone will correct me if I'm wrong
That's why i just wanted to double check, but i may still look into it when i get a chance.
Thanks again mate.
Cheers, Jack  Cool
1955 Holden FJ Ute
« Reply #6 on: October 05, 2013, 03:38:43 PM »
That's an interesting claim - I've never heard of it being done before.
Checking the parts book, the upper eccentric nut and the lower bush are the same between FJ and FE so the whole stub axle will bolt in as claimed in the post you refer to.
The stub axle itself looks entirely different between FJ and FE and the one thing that can't be checked from the parts book is whether the angles are OK.
From that perspective it would just be a matter of getting any early Holden stub axle, bolting it in and checking the king pin inclination (seeing whether the wheel stands up straight or not within the adjustment of the eccentric).
I will try to find out from some FX FJ people I know.
59Special
« Reply #7 on: October 05, 2013, 03:59:00 PM »
Thanks Ken, much appreciated
Cheers, Jack  Cool
1955 Holden FJ Ute
ridgey_didge
« Reply #8 on: October 05, 2013, 04:22:32 PM »
There is a set advertised in the July 2012 "Drive Chatter" newsletter of the Berrima District Historic vehicle Club Inc at berrimadistricthistoricvehicleclub.org.au
It is over 12 months old, but the guy might still have them.  The for sale ad is down the back of the newsletter - page 15.
Good luck.
David
59Special
« Reply #9 on: October 05, 2013, 05:11:52 PM »
Hi David,
Thanks for that mate, i'll go and have a look see.
Cheers, Jack  Cool
1955 Holden FJ Ute
Gary C
« Reply #10 on: October 05, 2013, 06:13:15 PM »
I have a set of early fe hubs in Perth but no stubs.
Gary.
59Special
« Reply #11 on: October 05, 2013, 06:35:39 PM »
Gary,
PM sent.
Cheers, Jack  Cool
1955 Holden FJ Ute
59Special
« Reply #12 on: October 05, 2013, 07:11:49 PM »
Gary,
I just phoned this other guy who had an advert for the ealy FE hubs, drums and bearings and he said there is an error in the advert as he does not have the hubs!, but does have the drums and bearings !
What other bits do you have with the hubs? EG: drums, backing plates, cylinders, bearings !
Let me know and hopefully we can work something out, i can do direct deposit.
Cheers, Jack  Cool
1955 Holden FJ Ute
Gary C
« Reply #13 on: October 06, 2013, 10:24:35 AM »
Jack, all I have is the hubs and a new set of bearings.I replaced mine with the later hubs and swapped my stubs.
Let me know if you want them, just pay postage.
Gary
59Special
« Reply #14 on: October 06, 2013, 11:02:30 AM »
Gary,
PM sent.
Thanks mate.
Cheers, Jack  Cool
1955 Holden FJ Ute
Page created in 0.026 seconds with 19 queries.
