July 21, 2025, 08:39:24 AM *
Author Topic: Accellerator shaft  (Read 2425 times)
« on: July 16, 2013, 09:16:43 PM »
Is it normal for the shaft to nearly be worn righ through and the pivot point to be cracked and twice the size as it should be, just not sure if this indicated high mileage or is a common feature.
collecta
« Reply #1 on: July 16, 2013, 10:00:13 PM »
 The one you describe sounds like high mileage but it is also common to crack where they bolt to the firewall.
« Reply #2 on: July 16, 2013, 10:32:11 PM »
ok, yeah this one is cracked where the shaft goes through. Not where the firewall holes are.
collecta
« Reply #3 on: July 16, 2013, 10:51:17 PM »
 but that is the part that bolts up? most i have seen snap/crack below the bolts.
« Reply #4 on: July 17, 2013, 02:18:45 PM »
i took pics on my build page, have a looksy
