July 19, 2025, 01:03:34 AM *
Author Topic: suicidedoors on fc two door  (Read 1604 times)
lumpy@goconnect
« on: September 21, 2000, 01:00:00 PM »
i have in my fc a 454 big block,chey 10 bolt ,tubs all thats missing is suicide doors i want some tips before i start cutting it up again because i had a hell of a time putting in the tubs in
FEV008
« Reply #1 on: September 21, 2000, 01:00:00 PM »
ive thought about this project myself... maybe cut the B pillar out from each side and replace them in reversed on the opposite sides using at least 5 mm plate under them to brace. (effectively having your rear door hinges facing forwards) Assuming u want a 2 door??? lengthen the doors by offset cutting two doors and cut and shut them.  you'll probably need some strengthening up the B pillars now to hold the additional weight anyway! So youve put in a 454 and tubbed it and need help with simple stuff like this?Huh best of luck
Page created in 0.038 seconds with 17 queries.
