August 21, 2025, 12:15:44 AM *
Pages: 1 ... 5 6 [7] 8 9 ... 48   Go Down
Author Topic: FC Ute  (Read 569785 times)
pedro
« Reply #120 on: June 28, 2013, 02:25:32 PM »
You making two?
Grin Grin Grin Grin Grin Grin
  Pedro
« Reply #121 on: June 28, 2013, 07:01:49 PM »
Well I am getting like you, except I don't have the same time frames, BUT, I have decided to build the FE 'HOW I WANT IT' and I don't care about what the engineer will think either (sort of), I will worry about that when and if I have to. I am trying to get into the old spirit of the 70's rebel hot-rodder and just build the bloody thing. All of this crap and regulation really got to me. I feel liberated now, dunno why, but all the blokes at the hot rod club have done it this way and it all turns out in the end, as long as the quality is right.
« Reply #122 on: June 28, 2013, 08:49:01 PM »
You
hmm you dont care but your measuring shackle plate with verniers for wear  Grin
Crumpsnr
Shellharbour NSW
« Reply #123 on: June 28, 2013, 09:36:51 PM »
 Cheesy Cheesy Cheesy Cheesy Cheesy Cheesy Cheesy Cheesy
« Reply #124 on: June 28, 2013, 09:49:46 PM »
Wrong car buddy  Cheesy Cheesy Cheesy Tongue Tongue Tongue
« Reply #125 on: June 30, 2013, 01:23:39 PM »
Ok todays effort
My question is how many are running  thermos on the front ?
They are stepped off the core 15mm ?
I have ran a 16 inch single before without any dramas i know they are more effiecent on the rear but they will be mounted on the drawn bracket at the bottom that will be welded to the radiator frame.
Im getting the lower spout moved up like a VK core.
should have just used a VK radiator. But i had this VL 5 litre one in the shed.
Everything fit sweet as and i have hidden the radiator which is what i wanted to achieve.
« Reply #126 on: June 30, 2013, 02:13:02 PM »
I'm running a 10" and a 12" on the back of the radiator so no gilmer drive for me Cry. Have to spread em wide too as the water pump would fowl on the fan. Only room I have in front of the radiator will be for the Air con condenser and the receiver drier.
« Reply #127 on: June 30, 2013, 02:57:38 PM »
Ah the joys of not having luxurys.
The way i see it fan shrouds caust lack of natural flow when driving causing the fan to come on more than normal and the flow lost with a air con condensor i think i should be right.
I think if you run HQ water pump and pulleys you will gain nearlly 20mm.
« Reply #128 on: June 30, 2013, 03:12:09 PM »
Bought this heater today
Check out the dimensions its tiny http://www.ebay.com.au/itm/261221075957?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
« Reply #129 on: June 30, 2013, 07:52:56 PM »
How the f&$k are you going to drive @ 40deg?
« Reply #130 on: June 30, 2013, 09:06:43 PM »
Get in  the 200 series .
Or just harden up.
« Reply #131 on: July 01, 2013, 08:47:51 AM »
Ok todays effort
Pete, I tried a few configurations and in my case twin 10 inch thermos on the front were not sufficient.
In the end a shrouded engine fan was perfect, with twin thermos on the front that would kick in at certain temp.  I wired them in to the ECU to come on as if AC was on.. so there was a temp set point and at certain speeds.
with that set up it could idle through Sydney CBD during peak summer without the needle on the temp gauge moving... a hi flow Milodon thermostat was also installed.
the rad was a 4 row, cut down to fit under the bonnet latch panel with torana tanks.
see thread
http://fefcholden.org.au/forum/index.php/topic,12243.0.html
pedro
« Reply #132 on: July 01, 2013, 03:35:31 PM »
Thanks for putting all the research into the heater/demister mate, made my choice a lot easier i just bought one too Grin Grin
  Pedro
« Reply #133 on: July 01, 2013, 05:09:10 PM »
Made the shroud today
Should look clean.
I love my waterjets.
Old_Mt_Isa_Boy
My Ute
« Reply #134 on: July 01, 2013, 05:23:49 PM »
Nice. Smiley
Wayne b
jwm
« Reply #135 on: July 01, 2013, 07:03:52 PM »
I ran what I think is a 16 inch thermo fan on the front (covered all of the radiator), I didn't think it was enough because the car kept over heating in traffic. I finished up installing an engine fan which made a huge difference and it was running within the temperature range but would occasionally still spit out a bit of coolant. A bit of mucking around but I finally worked out that the thermo was cutting in very late in the heat range, so I just hard wired it and it runs all the time at the moment ( a bit noisy) but still on the hottest of days can loose a bit of coolant.
My next job is to pull the radiator out and convert it to a recovery system, install a new thermo fan and to put a shroud on the engine fan / radiator, hopefully this ticks all the boxes and there will be no more issues.
« Reply #136 on: July 01, 2013, 07:27:08 PM »
I bought a Haltech 1000 series computer so it has all the out puts for fans ect so ill set it too cut in at a happy medium.
Was your fan hard on the radiator or stepped off ?
« Reply #137 on: July 02, 2013, 10:47:33 AM »
Finished modifying the original radiator support bracket.
Took the radiator in to get modified.
If I do something every day it will get done.
« Reply #138 on: July 04, 2013, 06:14:48 PM »
Merry Christmas to me or birthday whatever the occasion.
Computer arrived today
So did my heater pretty little thing 2 speed twin blower made in france for a change and a gates heater tap.
Im using a EH heater control
Gearbox arrived back today heavy duty bands, alloy pan, corvette servo and pin, manulised, cant wait to get this thing running..
TTV6FC
« Reply #139 on: July 04, 2013, 08:50:58 PM »
Awesome Pete,and a heater that works off a standard Samsung remote control!Now that's cool.... Tongue hehehe
« Last Edit: July 04, 2013, 09:01:14 PM by TTV6FC » Logged
Pages: 1 ... 5 6 [7] 8 9 ... 48   Go Up
