May 20, 2025, 08:04:14 AM *
Author Topic: ID Tags  (Read 3942 times)
JOX515
« on: November 18, 2012, 06:15:21 PM »
Afternoon one and all,  Is there anywhere on this great site where I can look up the meaning of all the numbers on my ID tag?  Cheers, Graeme
GMHwagoon
« Reply #1 on: November 18, 2012, 06:25:52 PM »
put the numbers up someone will decode them for you
JOX515
« Reply #2 on: November 18, 2012, 07:08:01 PM »
The numbers are (not sure whether I have given them to Ken, if not here they are):
No: FC-229-13011-A
Trim: 310-659
Paint: 256-7770
RPO: 253-9741
Graeme
« Reply #3 on: November 18, 2012, 08:39:09 PM »
This is the page to decode them yourself.
Which will tell you the following:
ID Plate
NO:    FC-229-13011-A
TRIM:    310-659
PAINT:    256-7770
     253-9741
RPO:
TOP
*** There could be inconsistencies in the identification data - please check you entered it correctly ***
Unable to calculate manufacture date without the engine number
That chassis number doesn't match the body plate
Other Details
Chassis Number:    x-xxxxx-x
Engine Number:    XXXXXX
Results and Explanation
FC-229-13011-A   Vehicle is an FC Special Station Sedan, the 13,011st manufactured in Adelaide, SA.
310-659   The Exterior Trim Code (310) describes this car as Two-Tone: Fountain Blue over India Ivory.
The Interior Trim Code (659) refers to: Viscount Blue & Black.
256-7770    The Primary (bonnet, guards) colour is India Ivory (in DUCO Lacquer)
253-9741    The secondary colour is Fountain Blue (in DUCO Lacquer)
x-xxxxx-x   The vehicle was assembled during Unknown, and was the FC (in any bodystyle) assembled in Unknown.
XXXXXX   Manufacture date (based on engine number) is Unknown (Not a valid grey motor engine number)
If you add the engine number and chassis numbers you'll get the rest of the data.
GMHwagoon
« Reply #4 on: November 18, 2012, 08:42:53 PM »
google
          fc holden ids
          click on tech info
JOX515
« Reply #5 on: November 18, 2012, 08:51:56 PM »
Thanks guys, much appreciated.  Will get the other numbers and plug them in.  That also gives me the colors to ask fo0r at the paint shop :-)
« Reply #6 on: November 18, 2012, 10:01:38 PM »
When you first logon, you have the map of Aus. under that there are three sub headings, click on technical info and this will open the screen you need. You can then input all your info, it will come up with the same info as RET gave you but if you have the chassis no. & engine no. you should get all the info.
Regards Jim
Page created in 0.05 seconds with 20 queries.
