August 19, 2025, 07:33:04 AM *
Author Topic: fc bonnet letters  (Read 5548 times)
fcee
« on: August 17, 2012, 03:46:43 PM »
Hi ,would like some guidance on how to remove and replace the holden letters on my fc .thanks, steve . Wink
Sale Victioria
« Reply #1 on: August 17, 2012, 06:25:38 PM »
Steve,
You will need something thin (maybe a feeler gauge or butter knife) to slide under the old letters and gently lever them off, put a little masking tape over the paint to protect it
I can't remember the access from the back, but if you could get to the back of them it would less chance of buggering your paint, by just donging them out with something
Each bonnet letter has 2 pins on the back
The larger pin needs to locate into a small clip that should have come in the new package if you got them from Rare Spares
I put the clip into the hole in the bonnet, then press the letter in or if stubborn tap with a rubber mallet
You may be able to use the existing clips, but they can be brittle
The smaller pin is just to locate the letter in the correct orientation
Good luck
fcee
« Reply #2 on: August 18, 2012, 04:27:45 PM »
IT seems access from the back is not an option ,but thanks for the tip ,cheers  Steve . Wink
Sale Victioria
waynos
patience grasshopper
« Reply #3 on: August 18, 2012, 05:12:57 PM »
ive seen plastic removal tools at a paint store........abit like a plastic screwdriver.
but as zulu said masking tape even a few layers just in case and a screwy with lots of care
ive pretty much chipped paint always taken badges off
im too impatient...........
« Reply #4 on: August 18, 2012, 06:37:50 PM »
Rather than a screwdriver - a paint scraper is the go. Strong wide metal blade, unlikely to damage the paint and applies even pressure on the letter so that the pin should not break
waynos
« Reply #5 on: August 18, 2012, 06:53:24 PM »
yeah thats why i always chip paint haha
Roybeth
« Reply #6 on: July 12, 2017, 06:32:53 PM »
Steve,
Good luck
Hi all, so I've bought some little barrel spring clips (or whatever you call them) to put my letters back on the bonnet.
1. do you push the clips from the outside into the holes(and then the little prongs catch on the inside) and then push the letters into them.
2. my clips seem a bit big when you just place them over the pins on the letters- or do they squish in a bit once you push them into the bonnet?
Thanks again
« Reply #7 on: July 12, 2017, 07:10:03 PM »
It doesn't sound right to me. I would try one out on a sheet of metal drilled with the right size hole and push the clip in to see what happens.
Roybeth
« Reply #8 on: July 12, 2017, 08:31:30 PM »
Sounds a plan, they seem to big to me, will see how it goes, ta
