May 24, 2025, 10:36:40 AM *
Author Topic: fc overlander ute  (Read 4697 times)
rod67
« on: June 24, 2012, 07:12:06 PM »
 >:(Hi just thinking about building a fc ute with a 4x4 chassis stupid question what chassis would i use and would i be able to put a 308 engine in it thank you Rod
freddyc
« Reply #1 on: June 24, 2012, 07:45:20 PM »
someone up here did a FJ ute on a hilux chassis, and widened the whole car to suit
Townsville North Queensland
rod67
« Reply #2 on: June 24, 2012, 08:25:12 PM »
Would i be able to use landrover lwb chassis 1974 model another silly question thank you Rod Huh
weddo
HIS, HER's & OUR's
billnjudiwedd@gmail.com
« Reply #3 on: June 24, 2012, 09:07:06 PM »
Hi Rod,
http://fefcholden.org.au/forum/index.php/topic,11731.msg69265.html#msg69265
I don't know if this link will work, but it is an FC on a landrover chassis
Weddo
john253a
« Reply #4 on: June 24, 2012, 09:54:28 PM »
once you fit a genuine 4wd chassis there are no power to weight restrictions, under new laws, so yes what ever drive train you can fit will work
one thing to remember with with a rebody is what ever chassis you use the car will be registered as that and not an fc, so all pollution and epa regulations will apply as if it was that vehicle, and an older engine or engine with higher emission can not be used unless on straight gas(any thing newer is ok), and if you chose an engine with better emissions controls you must leave them on, with emissions laws what ever has the highest emission controls is what you must apply to.
Good + Fast = Not Cheap
Cheap + Fast = Not Good
Good + Cheap = Not Fast
black57
feratrod
« Reply #5 on: June 24, 2012, 10:46:02 PM »
Same goes for airbags, collapsible columns etc so stick to an early year and reduce your obstacles.
Pinky.
A car on the road is worth 2 in the shed...
FE Standard rat rod
1965 GSM Dart - ex race car
1948 Singer 9
1954 Sunbeam Talbot drophead coupe
2 1960s custom fiberglass race cars
rod67
« Reply #6 on: June 25, 2012, 02:06:25 AM »
 ;)Thank you for the reply's, sorry for the silly questions;; trying to inlight my self;' thanks Rod
rod67
« Reply #7 on: June 26, 2012, 05:43:33 PM »
 8)Picked up 1974 LWB  Landrover rolling chassis today now to see how everthing lines up, thanks for the replys Rod
black57
feratrod
« Reply #8 on: July 08, 2012, 07:30:33 AM »
Hey Rod,
How did the landrover  chassis work out? Sounds like a big project and a lot of fun, so keep us in the loop if you can.
Pinky.
FE Standard rat rod
1948 Singer 9
