August 20, 2025, 07:59:04 AM *
Author Topic: Windscreen Wiper cable  (Read 4045 times)
graham_fuller
« on: March 17, 2012, 10:08:57 AM »
Hi all,
Is it possible to fix a wiper cable where the small ring on the wiper motor end freely slides up and down the cable?
Graham
graham_fuller
« Reply #1 on: March 19, 2012, 02:38:03 PM »
Has no one had this problem before?
Graham
« Reply #2 on: March 19, 2012, 04:30:47 PM »
I may be a bit slow but im confused
Can you post a pic of the problem part?
weddo
HIS, HER's & OUR's
billnjudiwedd@gmail.com
« Reply #3 on: March 19, 2012, 07:13:02 PM »
If its the bit that I am thinking of...you must have broken the end off the cable.
Cut the outer case back, slip the ring over the inner cable, heat the cable and tap it flat.
Weddo
« Reply #4 on: March 19, 2012, 09:01:55 PM »
Graham - it has taken me this long to work out what your problem is / was Tongue
THe small metal ring is supposed to move up and down the cable, just not come off the end.
The metal disc pulls the switch in one directio but the end of the wire pushes the switch the other way.
So your cable is not broken Grin
graham_fuller
« Reply #5 on: March 19, 2012, 10:06:37 PM »
Thanks.But how does that work with the nasco 2 speed electric version?
Graham
« Reply #6 on: March 19, 2012, 10:18:10 PM »
Hi Graham,
if you look here at the unit in Accessory of the Week
 http://fefcholden.org.au/forum/index.php/topic,7278.0.html
the fitting instructions show that the ring on the end of the cable is captive once the cable outer is clamped
So I would think as long as the ring can't fall off the end of the cable, all should be well
Gary
PS If you need to see one mounted, I can arrange to meet or send pics
graham_fuller
« Reply #7 on: March 19, 2012, 11:25:57 PM »
Thanks Gary,
I will have another look. Maybe the distance the outer comes out from the clamp is critical as they do say 3/8". Could you take a picture of the switch stem that holds the ring, maybe mine is not all there?
Graham
Page created in 0.03 seconds with 20 queries.
