September 07, 2025, 07:34:35 AM *
Author Topic: Booster for standard drum brakes  (Read 7692 times)
IFC.58
I love volkswagons too
« on: February 14, 2012, 12:15:54 PM »
Hello everyone
Can I run a booster with standard drum brakes
Which one
I have a vh44 on the shelf
And does anyone have photos of one fitted
Close up
Which pipes go where and which ones need
Modifying
Thankyou terry
hey my name is terry  i,m from brisbane
you,ll see me in my blue 58 fc wagon or
my other love a big red offroad baja vw
subaru powered and built to go anywhere
wave if you see me next time
« Reply #1 on: February 14, 2012, 01:10:48 PM »
Technically, yes you can, but it is not recommended as the brakes become very sensitive and are easy to lock-up.
I had boosted drums on my old Galaxie and it took months to get used to and emergency braking situations always got interesing  Shocked
I also had boosted drums on my FC Wagon and they were only a little better control wise, but again easily locked in an emergency.
John253a
« Reply #2 on: February 14, 2012, 06:12:29 PM »
i also agree with them locking up very easy, but only with standard width tyres 175 or 185
a have a 59 fc with drum's all round and vac assisted and i wouldn't have it any other way, i have full control over my breaks from nothing to full lock,
under normal driving its very easy to drive but as with all cars when you stomp on them you will get them to lock up (abs exempt) and in the wet its even easier, but, i do have have 205/55/15 on front and 225/50/15 tyres rear, its a totally different story when the the 185 go on
« Reply #3 on: February 14, 2012, 08:30:20 PM »
I have removed my booster and re built all the cylinders  as i kept getting brake lock up.
Turned out someone over the years had put the primary and secondary shoes on the passenger side ass about im thinking a drivers side set was fitted to passenger side.
But i actually prefer the feel  thru the pedal now there certainly not discs but certainly not horrible.
PETE
« Reply #4 on: February 14, 2012, 11:17:12 PM »
VH 44 is correct - pipe from master cyl goes to inlet closest to the booster vaccuum, outlets at the front of the nose piece
vmx-mxr
« Reply #5 on: February 17, 2012, 10:14:12 AM »
I know the diaphragms are a bit tricky (and expensive) to get hold of but what about the VH24 ? Weren't they the original set up a la Nasco ?
Dave Mac  Smiley
« Reply #6 on: February 17, 2012, 12:17:49 PM »
I have a brand spanker all new alloy vh24 thought they were for really rely old cars?
« Reply #7 on: February 17, 2012, 08:19:32 PM »
Yes VH24 is Nasco booster for FE FC, but the unit itself is hard to find and parts for it are even harder to get
geebeefc
« Reply #8 on: February 19, 2012, 09:47:57 PM »
Hi,I have a VH24 on drums, works fine. National Brake Co in Shepparton, Vic. overhaul these units.  Price is not cheap, but you get great service at a lower price than quoted by some other repairers. Many repairers dont have kits, either. Housings on VH24 boosters are of alloy and can suffer from corrosions as well, so this can be a problem on repair.  Glenn
« Reply #9 on: February 19, 2012, 10:02:46 PM »
Good work Glenn, I knew there was a guy out there who did them but was unsure where. VH24 does work well on FC (It is designed for 4 wheel drum brakes)
earlyholdenfan
« Reply #10 on: February 20, 2012, 11:23:02 AM »
Hydroboost in Melbourne can also rebuild /(possibly change over from memory) VH24's as well
Brilliant service and very knowledgeable!
Matt
http://www.hydroboost.com.au/
Page created in 0.034 seconds with 22 queries.
