July 21, 2025, 03:17:25 AM *
Author Topic: linkage set up  (Read 2281 times)
zl296
« on: December 04, 2011, 04:43:00 PM »
setting up my gear linkages,they where a little worn,bent
all good now...
just having a little trouble getting it to get gears off the column.
whats the trick to get it to work,adjustments etc.
gets gears on the box ok...
thanks.. Tongue
« Reply #1 on: December 04, 2011, 06:46:37 PM »
Have you set it up as per the manual?
If so then maybe one of the bends you have fixed is not quite right - do you have another linkage set to compare with?
zl296
« Reply #2 on: December 04, 2011, 07:46:40 PM »
thanks ken...
l will double check...
