July 21, 2025, 04:02:26 AM *
Author Topic: Boot lock cylinder  (Read 3443 times)
curlslinc
« on: November 29, 2011, 05:57:33 PM »
Hi all , any ideas on how to install - how does that back plate hold the cylinder lock in place, tricky holding with your finger !
« Reply #1 on: November 29, 2011, 07:19:50 PM »
It helps to have a second pair of hands, you need to make sure the plate is in place first, then place the barrel&arm through the boot & the plate. Make sure the arm is located in the lock fully & then push the plate up over the tabs in the barrel. It can be a bit of a pain due to the lack of room but you just need to keep at it.
Regards Jim
snuff69
« Reply #2 on: November 29, 2011, 09:11:34 PM »
I reckon that bugger took me a whole day to get in, no xtra hands just me. Like most of those hard to do things there is a special tool, but it can be done without it, just takes a day  Grin Grin Dave
« Reply #3 on: November 30, 2011, 05:07:44 AM »
The trick is to do it before you put the boot lid on .
Or get a 360 degree swivel wrist would also help.
You thing you have the little bugger and you feel again and its not between the little grooves.
fcdunedin
chris sayers
« Reply #4 on: November 30, 2011, 01:48:01 PM »
I used a couple of dabs of blu-tak to keep the sliding clip in place till i was ready for the arm twist manouver.
« Reply #5 on: November 30, 2011, 07:18:34 PM »
Thats not a bad idea, I'll pinch it when I put mine back together.
Thanks, Jim
ekute
« Reply #6 on: November 30, 2011, 08:55:30 PM »
Decking will help!Then you don't have to put it back in.....
curlslinc
« Reply #7 on: December 01, 2011, 08:28:00 AM »
Thanks for all the replies , some sound suggestions--seems like I will loose plenty of skin trying to put it back. Curlslinc
Page created in 0.037 seconds with 16 queries.
