July 15, 2025, 10:48:34 AM *
Pages: 1 ... 13 14 [15] 16 17   Go Down
Author Topic: My FC Rebuild  (Read 232675 times)
Old_Mt_Isa_Boy
My Ute
« Reply #280 on: June 20, 2015, 10:53:06 AM »
Good stuff Jim.
Wayne b
Re:
« Reply #281 on: June 20, 2015, 01:32:52 PM »
Some good progress there.
Deano.
« Reply #282 on: June 21, 2015, 12:02:20 AM »
Dam flu is getting around big time
« Reply #283 on: June 21, 2015, 09:44:24 AM »
Cleaned me up for two weeks, been off since the long weekend. Lot better now, back to work tomorrow and back on the car.
« Reply #284 on: July 01, 2015, 10:11:48 PM »
+2
As promissed, photos of the inside of the door skins painted and soundproofed using the rest of the lizardskin.
hopefully I'll get some more time this weekend and get the skins fitted to the doors.
DJ
« Reply #285 on: July 01, 2015, 10:57:33 PM »
Good steady progress Jim.
0417 270 315
« Reply #286 on: July 11, 2015, 05:05:04 PM »
Finally some time in the shed this afternoon, finished fitting up all the mountings for the windows and central locking. Also fitted the skin to the rear door and test fitted to the body before fully fitting the skin and priming it.Tomorrow I hope to fit the other three skins and prime them as well.
« Reply #287 on: July 12, 2015, 05:58:50 PM »
Finally all done, all four doors reskined, cleaned and under coated ready for refitting.
can anyone see a problem with the skins?
Didn't notice untill it was fitted, but the right hand skin doesn't have the hole for the door lock (must be a standard skin) no matter, I'll cut the old skin and use it as a template.
Now to fit the front and rear ends and get her back on the ground and fit and gap the doors and guards, then at long last PAINT.
DJ
« Reply #288 on: July 12, 2015, 11:22:21 PM »
Your shed must have been a lot warmer than mine this weekend Jim.
Very thorough job.
0417 270 315
« Reply #289 on: September 10, 2015, 06:32:47 PM »
Been at it again over the last few days, had a chance to get some of the more tedious jobs done. Smoothed the guards and fixed a few rust spots that came to light after blasting. Also smoothed the door openings and pillars and primed them ready for final rub and high fill, so all the work that has been done now looks like the rest of the car. Also been working on the EJ rear end, getting it ready to fit so I can get her back on her wheels.
graham_fuller
« Reply #290 on: September 10, 2015, 07:42:39 PM »
Great work Jim. Keep it up.
DJ
« Reply #291 on: September 10, 2015, 10:15:03 PM »
Bring the warmth & daylight saving.
0417 270 315
« Reply #292 on: September 11, 2015, 11:09:23 AM »
Sounds like we all have our hands full at the moment..
Any progress is good progress..
collecta
« Reply #293 on: September 11, 2015, 07:28:54 PM »
Harko's 20 minute rule has always resonated with me.
« Reply #294 on: September 27, 2015, 09:22:19 PM »
Got some more done today, pulled the front frame off the rotisserie so I could clean up, smooth  and prime the firewall.
Also cleaned and painted the gearbox cover, steering column plates and front bumper irons. Imgur has changed it's format again so once I work it out I'll post some photos of the progress. All these small jobs are adding up and gives me something to do while I'm waiting for the rear end to come back from being blasted. Each little job gets me another step closer to being ready for paint.
« Reply #295 on: September 28, 2015, 05:38:36 AM »
All this wet weather we have had has put me behind a few days waiting for the subframe to come back from blasting as well.
A pile of bead blasting for the T/A today  Cheesy
Hopefully get some etch primer on all the parts and engine this afternoon..
« Reply #296 on: October 11, 2015, 10:33:58 PM »
Finally, imagur is back to normal, so here are the photo's of the work so far.
also paint stripped and cleaned the front end today but was to dark to take photos by the time I finished, will post them in the next few days.
« Reply #297 on: February 08, 2016, 07:18:09 AM »
Yay, finally picked up all the brake and clutch parts yesterday (the only problem when you tell a mate your not in a real hurry).Now hopefully I can get some time to myself and get back into the shed and get the car finished.
« Reply #298 on: August 21, 2016, 04:53:32 PM »
Can't believe it's been 6 mths since I've done any work on the old girl, I have been kept busy around the house and our daughters new home at Bingara Gorge. I have had a chance to dismantle the EJ rear end that will go into the FC and clean it up and remove the old bearings and wheel studs from the axles. Everything has been stripped back to bare metal and repainted in satin black, new bearings, seals, wheel studs and crown gear and pinion will be fitted along with the new drums, brake shoes and wheel cylinders ready for refitting.
The down side is I will have to replace the outer sills as the old repo sills are out of shape and the front doors sit over the top of the sill on both sides. At least I have been lucky to pick up a pair of nos outer sills, so hopefully they will fix the problem.
« Reply #299 on: December 06, 2017, 08:27:28 AM »
+2
Well the FC and us have a new home and I have retired from full time work after 50 years. Once we have fully unpacked and settled in The plan is to finish of the FC and get her back on the road.
Will keep you posted,
Pages: 1 ... 13 14 [15] 16 17   Go Up
Page created in 0.055 seconds with 19 queries.
