August 25, 2025, 01:17:51 AM *
Author Topic: 138 grey engine motor running problem  (Read 4162 times)
fe
My FE
« on: September 18, 2011, 09:55:53 AM »
I have a Fe with a 138 ,I went for a drive yesterday and when I accelerate heavily the motor backfires [farts]
and the whole car jerks badly ,I checked the spark plugs they appear ok ,is this a timing problem or just a dirty set of points ,its now idling badly
FE
« Reply #1 on: September 18, 2011, 01:39:53 PM »
Check distributor cap, rotor button and leads
« Reply #2 on: September 19, 2011, 05:58:01 PM »
Could be a faulty carby accelerator pump, though usually they don't backfire, just jerk.
Pull the aircleaner (engine off), get a friend to pump the accelerator a few times while you look down the carby throat - you should see fuel squirting if the pump is working (or as Bill Cosby put it "gas shooting over your left shoulder"  Grin.
Harv.
FCGos
« Reply #3 on: September 19, 2011, 07:19:10 PM »
fe
As well as the previous posts check that there is no air leak at the carburettor which is usually caused by the carburettor and base becoming loose, they are both held together by two large screws which are accessible for tightening once the air cleaner is removed.
Cheers Wayne
GOA350
« Reply #4 on: September 19, 2011, 09:25:08 PM »
you could have done a timing gear which would put your timing out
fe
My FE
« Reply #5 on: September 21, 2011, 08:39:17 PM »
Thanks Guys I bought another dizzy cap and will let you know soon what the result soon
will check all comments given,cheers
fe
Page created in 0.022 seconds with 19 queries.
