July 18, 2025, 11:04:41 AM *
Author Topic: 56 FE SPECIAL.  (Read 2585 times)
fink fc
« on: August 30, 2011, 10:07:10 AM »
I HAD A LOOK AT A 56 FE SPECIAL FOR A FRIEND OVER THE W/END.THERE IS NO CHASSIS NMBR ON THE S/FRAME''IS THIS HOW THEY ARE?'' ALSO IT HAS GUARD & F/DOOR SIDESTRIPS THE SAME AS FC SPECIAL.IT'S A GENUINE 90,000 CAR I'M A BIT CONFUSED.THANKS, GAZ.
« Reply #1 on: August 30, 2011, 02:54:52 PM »
GAZ, It's hard to spot the early FE chassis no, it's just above the battery and is only in a small sized font, often hidden by splashes of battery juice
The guard strip is the same as FC except it has the running Holden script stamped into it
Front door strip is same as FC, it's from the back door back that there is a difference between them
Garrry
fink fc
« Reply #2 on: August 30, 2011, 05:02:06 PM »
THANKS GAZ,IT HAS THE SCRIPT IN THE GUARD SREAR.I WILL CHECK THE PSNGR SIDE LIKE YOU SAID FOR THE NMBRS. THANKS.
« Reply #3 on: August 30, 2011, 06:55:37 PM »
I assumed my car had police numbers as i thought it had NOS front end didnt know FE was in a different spot to FC weirdo FE designers
You learn something everyday.
Page created in 0.033 seconds with 20 queries.
